no power to wheels!!!!
Old Aug 27, 2008 | 09:25 AM
mini4christine's Avatar
mini4christine
So a new problem arises,
My wife was driving home when all of a sudden there is no power to the wheels, she was in gear, going around a corner, there was no noises, no leaks, no smells, nothing!! I get in the car and it starts fine, try to put it in gear and it feels fine, tried them all, even reverse, clutch feels ok, its like the motor is completely seperated from the transmission.
Anyone have any advice?? besides setting it on fire
Thanks,
Jake
Old Aug 27, 2008 | 09:37 AM
03BRG's Avatar
03BRG
Broken half shaft. I have heard this before in a older post
Old Aug 27, 2008 | 09:53 AM
mini4christine
So does anyone have a diagram/pic of how the engine/clutch/trans work together and how do I get to the half shaft, or a link to a diagram?
Thanks,
Jake
Old Aug 27, 2008 | 10:44 AM
AutoXCooper.com's Avatar
AutoXCooper.com
Here it is,
Old Aug 27, 2008 | 10:47 AM
03BRG's Avatar
03BRG
www.realoem.com will show you the parts the half shafts are the drive axles to the front wheels. With a open diff Mini only 1 wheel drives and if one of the axles break it will just sit and not move the car. Do you have the 5 speed or 6 and what year? It could also be the clutch or tranny but the axle fits this problem better.
Old Aug 29, 2008 | 09:18 AM
mini4christine
Well, I raised the car up and when I spin one wheel the other just sits there, not whats suppose to happen, so im thinking differential is broke
Old Aug 29, 2008 | 10:49 AM
03BRG's Avatar
03BRG
Not to say its not but when you did this was the other wheel on the ground or both in the air?
Old Aug 29, 2008 | 05:29 PM
Yo'sDad's Avatar
Yo'sDad
If the tranny is in neutral, one wheel on the ground, the other wheel can turn freely.. you are turning the tranny input shaft, if the tranny is in gear and this happens, then you have stripped something, some dif gears, the axle splines where they fit into the outer hub.
YD
Old Aug 29, 2008 | 09:19 PM
Ancient Mariner's Avatar
Ancient Mariner
I'll go with 03BRG, sounds like one of the CV shaft joints bit the bullet.
Symptoms fit.
Old Aug 30, 2008 | 09:07 AM
Crashton's Avatar
Crashton
CV joints can & do go bad. It has been my experience that they make a wail of a racket before they do & make that noise for quite a while before their complete failure.
I'm thinking it is clutch related. An outside very remote possibility is a broken main shaft in the transmission.
I hope it is only the clutch. Let us know what it is when you find out.
Good luck.
Old Aug 30, 2008 | 12:09 PM
Ancient Mariner
Good luck.
As one O.F. to another, I agree it could be the clutch, but I've had at least two CV joints go out on me (VW GTi and Toyota Corolla) both while in the middle of a turn, and both without a sound -and no pre-breaking noises. Almost like someone stole the tranny: one minute it's driving just dandy; the next 'vrooom, vroooom!' -no move.
Old Aug 30, 2008 | 02:35 PM
Crashton's Avatar
Crashton
Thanks fellow O.F. never heard of that before, but I do believe you. I hope for the OP's sake it is a CV joint failure.
Old Aug 30, 2008 | 04:08 PM
Ancient Mariner
Amen, brother. Muuuuuuch cheaper than a tranny or clutch. And a lot less down time.
Old Sep 3, 2008 | 05:02 PM
mini4christine
Hi, i thank you all for the input, and right now both wheels are off the ground, when the cars in neutral turn one wheel and the other doesnt spin, i guess thats ok, when i put in in gear, 1st, turn one wheel the other moves! ok, so i start the car and it spins the wheels now!!, So im thinking the clutch has suffered some failure, my wife may have overfilled the engine with oil, maybe that got past the seal and ruined the clutch, because there is more oil under the clutch housing than normal.
Thanks in advance,
Jake
rob&JCW
Feb 13, 2023 07:03 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Aug 21, 2015 11:25 AM
yashmack
Aug 15, 2015 03:11 PM
