Suspension Strut brace observations
Old Aug 6, 2008 | 11:24 AM
OldRick's Avatar
OldRick
I recently had my `05 S aligned, after adding urethane control-arm and trailing-arm bushings.
While there, an experiment occurred to me: while the alignment machine was still hooked up on the wheels, we tried to see how much change in camber my OMP strut-top brace was able to make when tightened or pre-loaded. My reasoning was that if the brace were to be effective, it would have to be by resisting changes in camber caused by strain on the suspension, e.g. during fast cornering.
So we tightened and loosened the OMP bar, and saw absolutely zero change in the camber - not even .01 degree. What was readily observable was that the bar was bulging up under the strain as it was tightened, since the strut towers weren't moving.
My conclusion is that even this relatively stiff strut brace is not going to make any appreciable change in the static or dynamic camber of the car. I confirmed this by removing the bar, and taking a test run on some of my local hairpins. I observed that, unlike the lower bar or cabrio braces, there was no apparent change in the handling of the car without the brace.
However, I did reinstall the bar, but for a different reason - it apparently redistributes or damps vibrations in the chassis that lead to interior noises. Just as I had noted when I installed it, it does reduce the cheap-plastic noises in the dash and interior of the car.
So I suggest not buying a strut-top brace for handling improvements, as I couldn't find any, but consider one if you are concerned with quieting your car - the improvement in perceived build quality from eliminating all those little ticks and cricks is considerable.
Old Aug 6, 2008 | 04:43 PM
oxtox's Avatar
oxtox
i don't think top braces do much for our cars....but i suspect the plates (i.e. m7) do help with mushrooming if you want to stiffen the front, under braces i.e. m7, omp, tsw do much more and are immediately noticeable
Old Aug 6, 2008 | 04:46 PM
OldRick's Avatar
OldRick
Agreed - I've got the OMP lower brace and the Cabrio diagonal braces - both do more than the strut-top for both handling and noise reduction..
Old Aug 6, 2008 | 04:52 PM
Dr Obnxs's Avatar
Dr Obnxs
Andy @ Ross-Tech
would be proud!
Matt
Old Aug 6, 2008 | 05:32 PM
TWON's Avatar
TWON
Hmmm, was never interested much, as I am happy with the handling I currently have..... but noise reduction!.......... Oh no....... more money to spend now Thanks a lot!
Old Aug 6, 2008 | 06:59 PM
HighLife4136's Avatar
HighLife4136
Bravo OldRick
Old Aug 24, 2008 | 05:26 PM
scottab36's Avatar
scottab36
Adding the strut tower brace to a car will only make a noticable improvement if the quality of the car is lacking in structure design and materials used to build the car. I have had them on two different cars and they made a big difference.
I have also had other MINI folks tell me not to purchase the strut tower brace for the mini.
Old Aug 25, 2008 | 11:54 AM
ofioliti's Avatar
ofioliti
... if the brace were to be effective, it would have to be by resisting changes in camber caused by strain on the suspension, e.g. during fast cornering.
... we tightened and loosened the OMP bar, and saw absolutely zero change in the camber - not even .01 degree. What was readily observable was that the bar was bulging up under the strain as it was tightened, since the strut towers weren't moving.
Elegant experiment. Thanks for sharing.
Old Aug 29, 2008 | 10:49 AM
OldRick's Avatar
OldRick
BTW, Iif I were concerned about strut tower deformation, I'd get the new Mini-Madness Strut Tower reinforcement plates, not the M7 or Kraven decorative tower-toppers.
Old Sep 1, 2008 | 07:49 AM
jhiggs26's Avatar
jhiggs26
But the Mini Madness will raise your front end by 4mm if you don't have adjustable coilovers. Neat product though!
Jeremy
Old Sep 1, 2008 | 09:41 AM
Dr Obnxs's Avatar
Dr Obnxs
And if you do have adjustables
you loose 4mm of travel to maintain the same height.... Really, there is no perfect solution... The plates on the top help, but really aren't the best design. Plates underneat work better, but have issues with ride heigth. Best way to go is camber pates that are stronger and don't mess with ride heigth... But that's more money.
Six of one, half dozen of another, or a dozen and a half of a third!
Matt
Old Sep 2, 2008 | 07:30 AM
OldRick's Avatar
OldRick
Contrary to the info in their image, the M-M reinforcement plates are actually 3.5mm thick. (corrected)
Old Sep 2, 2008 | 10:01 AM
MINI-Madness's Avatar
MINI-Madness
The plates are actually 3.5mm thick, sorry for the confusion, just corrected the site.
Old Sep 2, 2008 | 10:19 AM
OldRick's Avatar
OldRick
Old Sep 13, 2008 | 10:31 AM
OldRick's Avatar
OldRick
It has since occurred to me that the second reason why a strut-top brace is useless on a MINI is because there is no way to install a STRAIGHT brace; it has to curve several inches to clear the top of the airbox and ECU.
A curved brace won't limit tower motion much, because it is simply a large curved spring, which is easily compressed (arched) or flattened by any strain put on it between the towers, witness the relatively-stiff OMP, which arches and flattens when lengthened or shortened with the adjustment turnbuckle.
A straight-line brace, as can be fitted on many other cars, even if flimsily constructed, is not compressible or stretchable due to tower-top stresses, and can actually prevent motion between the two towers, which no curved brace can do effectively, particularly the flimsy offerings from many vendors.
Old Sep 13, 2008 | 12:43 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Does this work?
Beats the heck outta me. But it looks like part of an Autobot. So therefore it is worth what it cost, whether it does anything or not.
And the thing is so freakin stiff you can grab the center of it and move the car back and forth, with no noticeable flex laterally or vertically on the bar. Other bars I've tried that with have flexed before the car moved... I'm pretty confident it's going to add some level of stability to the top of my struts.
I'm not sold on the concept that the only way a strut bar can help is to prevent dynamic camber changes that might otherwise occur... the fact that the bar reduces NVH or "rattles" leads me to believe that it can also be effective in reducing, damping or otherwise limiting the effects of chassis vibration... which is the enemy of grip IMHO...
Old Oct 14, 2008 | 04:56 AM
Red Bull's Avatar
Red Bull
Originally Posted by BlimeyCabrio
Does this work?
I love the look of that bar....where did you get it and how much did you pay?
Old Oct 15, 2008 | 07:19 AM
Dr Obnxs's Avatar
Dr Obnxs
It's a british vendor..
GT Tuning. check over on Mini2 for the link.... He makes lots of good stuff, but with the dollar what it is, it's not cheap!
Matt
Old Oct 15, 2008 | 07:25 AM
BlimeyCabrio
Yeah - they're insanely expensive in US dollars, with shipping.
If I had seen the Ireland bar first, I probably would have bought that, for the money. But I LOVE the GTT brace...
http://www.gtt.uk.com/home.asp
Old Oct 15, 2008 | 08:32 AM
MiniMacPR's Avatar
MiniMacPR
It sure makes air filter maintenance harder, though. At least in the oem filter placement position.
Old Oct 15, 2008 | 08:34 AM
BlimeyCabrio
And oil changes... and header installs, and, and, and...
But not really a big deal - it's only six nuts. I can remove the bar in under a minute if my impact driver is handy.
YaTuSabe
Aug 23, 2018 11:41 AM
OutMotoring
Mar 3, 2017 06:29 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
buggyeye401
Oct 1, 2015 01:22 PM
Suspension Products
Oct 1, 2015 11:53 AM
