Drivetrain 11.86 psi of boost........265whp
Old Aug 1, 2008 | 01:06 AM
Revolution Mini Works's Avatar
We have been playing with combinations and here are the results
RMW Head
RMW Cam
RMW 440cc injectors
RMW Race header/exhaust
RMW CP Pistons
RMW Laminova Water to Air intercooler
1.6L engine
JCW pulley
inlet temps at the end of the dyno run.........92deg F at 8k
for those of you that have scan gauges..... humor yourself and try this little exercise..... go from 0-90mph.........slam on the brakes and do it again and see what your intake temps are...... these were 107deg F at the end of the runs Once you do this you will appreciate the above
This was comparing this setup to a very similar setup running almost 4psi more of boost
Old Aug 1, 2008 | 02:13 AM
Rausner's Avatar
Rausner
This is getting silly. Can't wait to get mine tuned. The engines do seem to be as restricted from factory as the 2jzgte's and rb26dett's! :O
Jan for president!
Old Aug 1, 2008 | 04:45 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Wow.... that would seem to suggest that flow and charge density trumps boost, eh?
You say the higher-boost setup was "very similar" - what specifically did it have?
Very interesting...
Old Aug 1, 2008 | 04:56 AM
newbs49's Avatar
newbs49
So when is mine going to be ready???????????????????
You got the permission slip!!!!!!!!!!!!!!
Old Aug 1, 2008 | 04:59 AM
minimarks's Avatar
minimarks
That sort of backs up what I have read before, that while spinning the SC faster there is a point where the heat build up degates the short lived gain... You da man Jan.
Old Aug 1, 2008 | 06:08 AM
MINIFVR's Avatar
MINIFVR
Very impressive!
Is this the first RMW Laminova W2A IC?
Old Aug 1, 2008 | 06:10 AM
these are just natural progressions .... while others talk the walk....
we walk the talk
we will be running this setup for awhile but rest assured after fully tested you can expect to get on the phone and say..........
I want a kit........
we are not ready to release the details about how we do it.... but we do it and you can bank on that
Old Aug 1, 2008 | 06:12 AM
Originally Posted by MINIFVR
Very impressive!
no, there are 3 of them out there and more on the way
Old Aug 1, 2008 | 06:18 AM
MINIFVR's Avatar
MINIFVR
Is it similar to the MM W2A system...are there any major design differences?
(sorry to deviate from the thread)
Old Aug 1, 2008 | 06:21 AM
AllBlack05S's Avatar
AllBlack05S
ahxactly. Volume + Velocity + Density is the key.
Jan knows his stuff fo sho. Just wish I could afford his stuff LOL.
Jan need another daily driven test platform volunteer?
Old Aug 1, 2008 | 06:24 AM
Luys's Avatar
Luys
WoW
Old Aug 1, 2008 | 06:26 AM
no problem.... this is about a "system" to achieve these results.
ours is a Laminova type cooler, same as what's used on the new ZR-1
yes.... it's much different
Last edited by Revolution Mini Works; Aug 1, 2008 at 06:29 AM. Reason: grammar... a wonderful thing
Old Aug 1, 2008 | 08:25 AM
hemiheaded18's Avatar
hemiheaded18
we walk the talk
I assume from these comments this will be avilable as a top end kit?
Old Aug 1, 2008 | 09:00 AM
MINIFVR's Avatar
MINIFVR
Ahhh...the power of information.
Old Aug 1, 2008 | 09:01 AM
Myke@RPI's Avatar
Myke@RPI
say in 2 years I get this, your head, cam, stroker... will you retune my car... AGAIN? hahaha
Old Aug 1, 2008 | 09:04 AM
sure no problem
as for Hemi... yes it will be offered as a high output low intake temp kit
Old Aug 1, 2008 | 09:33 AM
//MZero's Avatar
//MZero
Wow Jan, Wow
Old Aug 1, 2008 | 10:10 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
That is just sick off of 11.86 psi ridiculous
Old Aug 1, 2008 | 10:16 AM
hemiheaded18
sure no problem
Now, is this something that could be improved on by adding, say a 15% or is this kit designed to keep boost low along with temps? The only thing high seems to be HP!
Old Aug 1, 2008 | 10:19 AM
sure you could do that but then up go the inlet temps.......
this is more of a track application as a high rev'ing low IAT setup
look at the power band and IAT's....sick stuff
as for even more power.... it's on the way
Old Aug 1, 2008 | 10:27 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
So the w2a and samller pulley was what was the magic on this combo? Or strong factory car?
Jack
Good job btw
Old Aug 1, 2008 | 10:34 AM
Jack
Good job btw
it was a combination of sorts.... we aren't ready to give the competition any ideas yet..... by the time they get here we will be on the next and ahead again......
games that must be played
Old Aug 1, 2008 | 10:38 AM
littlehandegan
Sending a pm.
Old Aug 1, 2008 | 12:12 PM
mini_racer's Avatar
mini_racer
Inconceivable !
Very impressive Jan
Old Aug 1, 2008 | 12:20 PM
littlehandegan
One more question, prior the these new mods, this car pulled 253 correct?
