R56 Fuel Filter Change
Old Jul 22, 2008 | 04:55 PM
scottab36's Avatar
scottab36
Fuel Filter Change
Has anyone changed thier fuel filter on the 07 MCS? I have 22K miles on mine and was wondering if this is something I should be concerned about.
Old Jul 22, 2008 | 06:49 PM
mellowmcs's Avatar
mellowmcs
fuel filter does not need to be changed that often. I'd say 75-100K miles before you need to change it.
Old Jul 22, 2008 | 06:57 PM
maximus96's Avatar
maximus96
really? i typically change it on my cars around 25-30k miles.
Old Jul 22, 2008 | 07:00 PM
mellowmcs's Avatar
mellowmcs
my experience is mainly with bmws but bmws recommended interval is 100K miles. i'll have to check the owners manual for the MCS but I've no reason to suspect other wise. but i could be wrong!
I'm sure you're not hurting anything by changing the filter sooner
Old Jun 11, 2009 | 04:56 PM
r56cooper's Avatar
r56cooper
how do you change the fuel filter on r56?
Old Jun 11, 2009 | 07:28 PM
kukaepe's Avatar
kukaepe
I'm wondering if fuel filter changes at 25-30K miles might be a good idea given the high fuel pressure that the S directed engine operates at. I understand the pressure is 144 bar or approximately 2000 psi. Most port injection operates around 50 psi. Don't know cost of filter or location but perhaps it is worth more frequent changing to hedge one's bet on damage to expensive downstream fuel system bits.
Old Aug 13, 2009 | 06:49 AM
r56cooper's Avatar
r56cooper
has anyone changed their fuel filter? on the '07+ models?
also, all this talk about sludge at bottom of fuel tanks, contaminated oil . . .
makes me want to replace my fuel tank as well, or at least clean it if possible?
Old Aug 13, 2009 | 07:14 AM
Robin Casady's Avatar
Robin Casady
From the Owner's Lounge, it doesn't look like the fuel filter is in the scheduled maintenance for the free service period. I didn't find it in Service II.
I believe you access it from under the rear seat and remove the oval panels, but I'm not positive.
Old Aug 13, 2009 | 11:35 AM
scottab36's Avatar
scottab36
Looks like the fuel filter repair kit is about $61.00 on the REALOEM site.
http://www.realoem.com/bmw/showparts...77&hg=16&fg=15
Old Aug 13, 2009 | 06:52 PM
ron-s mini's Avatar
ron-s mini
Now if we just new where it was located?
Old Aug 14, 2009 | 02:58 AM
scottab36's Avatar
scottab36
Access cover for the fuel filter is located under the back seat.
Old Sep 23, 2009 | 12:32 AM
r56cooper's Avatar
r56cooper
the right back seat
i just replaced mine yesterday @ 21,000 miles
not too dirty
i'd recommend changing it every 30,000 miles
Old Nov 22, 2009 | 09:08 AM
scottab36's Avatar
scottab36
Originally Posted by r56cooper
the right back seat
not too dirty
I went over 44K miles on Louise yesterday. I already have the fuel filter kit in hand. How much work was involved and are there any special tools required?
Thanks for the info!!!
Old Nov 22, 2009 | 10:36 AM
r56cooper's Avatar
r56cooper
lift up rear seat
remove cover under right rear seat (6 nuts i think)
lift up fuel filter, when disconnecting it, it may squirt a bit of fuel around, prepare for this
suck out dirty black fuel (i used a lil shot glass haha)
replace w/all the rubber components
done!
fairly easy, pretty simple, takes about 15 mins
Old Dec 22, 2009 | 02:14 PM
DMBFan2's Avatar
DMBFan2
Have you replaced the filter? I am having a problem putting the locking ring back on. It starts to thread but then pops off. Any ideas?
Old Dec 22, 2009 | 02:37 PM
Robin Casady
I've not done it. Just seen the access panels when doing a rear-seat delete.
Old Dec 22, 2009 | 02:41 PM
skippydog's Avatar
skippydog
I wonder if it is close to this?
Mini Fuel Filter Change
Old Dec 22, 2009 | 02:54 PM
DMBFan2's Avatar
DMBFan2
That is the set of instructions I have followed EXCEPT the part at the end that says "screw on the locking ring". It sounds simple but I have been trying to do this for an hour now. The SOB wont tighten on! It gets a little tight then pops off.
Old Dec 24, 2009 | 07:18 PM
4cefed4's Avatar
4cefed4
Unless you're putting extremely suspect gas into your Mini (which I hope you're not...) there is no point in changing the filter that often. I usually change them between 75k to 100k, and I have never seen one that was dirty even in that interval.
Old Dec 25, 2009 | 03:33 PM
rrcaniglia's Avatar
rrcaniglia
Not necessary, but wouldn't it be fun?
Old Dec 26, 2009 | 05:51 PM
DMBFan2's Avatar
DMBFan2
"Unless you're putting extremely suspect gas into your Mini (which I hope you're not...) there is no point in changing the filter that often. I usually change them between 75k to 100k, and I have never seen one that was dirty even in that interval."
Changed mine @101k miles and it was dirty!
Old Jan 10, 2010 | 07:32 PM
Noegel's Avatar
Noegel
Any results or tricks to this?
Old Jan 11, 2010 | 03:19 PM
DMBFan2's Avatar
DMBFan2
I am not sure why but when i went back (for the 10th. time) and took the filter out and reapplied all of the seals (fixing the inner large oring that fell off) the bloody thing screwed in with ease. Maybe it was the oring---I dont know - just glad that I will not need to do this for a VERY LONG time!!!
Old Jan 12, 2010 | 04:25 PM
Noegel's Avatar
Noegel
That's great.... I'm planning on doing this here shortly. Probably at 40,000 miles which is less than 2000 away... I'll post if something is tricky.... thanks!
Old May 25, 2010 | 07:16 AM
adam_randell's Avatar
adam_randell
any chance of a picture tutorial on how to do this?
