track wheels and tires
Old Jul 17, 2008 | 02:19 PM
2002s's Avatar
2002s
Want to buy some track wheels and R compound tires.
Does anyone know what the largest size or best size wheel that will fit on a stock s car with sport suspension is?
Thoughts on R compounds? Shaving? Heat cycling? thx
Old Jul 17, 2008 | 03:54 PM
bean's Avatar
bean
i can answer this one. it's all about the $$$. light weight wheels cost more than heavier ones. sticky tires don't cost much more, but they will wear out faster, so the $$/heat cycle is higher. my formula was: buy the strongest, lighest wheel that i could afford (SSR type C-RS). start out w/ moderately priced, relatively long lasting r-comps (RA-1's). if the manufacturer recommends shaving a particular tire for track use, do it. contrary to intuitive thought, they will last longer and perform better. as the disease gets to more advanced stages.....use your original wheels for wet/intermediate tires, order two sets of custom racing wheels so that you can properly heat cycle your new slicks, get the stickiest and widest tire that you can stuff under the car to take advantage of the bbk that you added and all of the suspension mods. ask me how i know.....
size is a function of many factors. do you need (or will you need) clearance for a bbk? smaller diameter wheels are generally lighter. someone elses stock takeoffs might be a good starting point (and can be found relatively cheap) adding camber increases the max size that will fit by tucking the tire inside the wheel well. on a stock setup, a 215 tire is about as wide as you can go. that said, i can stuff a 225/40/17 Hoosier R6 under mine and will be trying a 235/620/17 Hankook F200. i am confident that it will work. available sizes are more limited w/ r-comps. get them well ahead of anticipated use and figure out what spacers, grinding, etc. may be required.
Old Jul 17, 2008 | 04:05 PM
2002s's Avatar
2002s
and the size wheel that you were able to buy plus offset to fit the mini??? thanks,
Old Jul 17, 2008 | 04:11 PM
bean's Avatar
bean
i require 17" wheels to clear the bbk. my SSR's are 17X7.5 w/ et42. my kodiaks are 17X8 et40.
Old Jul 17, 2008 | 04:38 PM
snid's Avatar
snid
Figure out what tires you want to run, then see what sizes those tires are available in. Then decide on the wheels.
It sucks to buy a wheel and then find out that there aren't any tires you like available in that size... like RA-1 sizes are good for 15" and 17", but not for 16".
Old Jul 18, 2008 | 06:31 AM
2002s's Avatar
2002s
thanks, still sorting it out. thanks for your sharing.
Old Jul 18, 2008 | 07:11 AM
bean's Avatar
bean
my buddy, mct, made a spreadsheet to make it easier to keep track of the possibilities. Easy to eliminate many combinations this way.
Old Jul 18, 2008 | 10:22 AM
batrugger's Avatar
batrugger
Stay away from the 16's. The only thing you can find for them are Hoosiers and they are $220 a tire. You can get Rota Slipstreams that are under 15lbs and will cost less than $500
Old Jul 18, 2008 | 10:44 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
Go smaller if you can. Smaller is lighter and cheaper. I have the Wilwood 11.75 BBK and I still use 15"s for the track. Team Dynamics Pro Race 1, 15x7, et+35. Then I use Toyo RA-1s in 225/45/15. The combo is light, cheap, and smaller than stock so the improved gearing makes the car faster.
pre shrunk
Aug 18, 2015 11:09 AM
sabjcw
Aug 14, 2015 07:40 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
nomar116
Aug 9, 2015 09:42 AM
