Interior/Exterior Weight Limit on Tach?
Old Jul 15, 2008 | 07:53 PM
MiniSuperCooper's Avatar
MiniSuperCooper
I'm thinking about mounting my StreetPilot onto my tach. My only concern is the weight. Is it possible to damage anything with the added weight?...hitting pumps and all? Just looking for other MINI owners' thoughts.
Thank you,
Seth
Old Jul 15, 2008 | 08:17 PM
AutoXCooper.com's Avatar
AutoXCooper.com
I have my GPS mounted on the back of my Tach. I had the idea, a friend built it for me. I just took the below pics a few mins ago, but have had it setup for 9 months without any issues.
We removed the tach, took it apart and found on the inside back cover there is space for very small screw heads. We drilled 4 of them. The steel piece is bent greater than 90 degrees to not rub on dash. Before putting the tach back together, we bolt the steel on. Then I drilled a small hole in the GPS part to run zip ties to secure it altogether. Then added a sticky felt pad to the bottom of GPS where it rests on top of tach. I hope this plus the pics helps. I'm sure it could be done better and look forward to seeing how others make/did it better. I'm very happy with the setup, I can use my GPS without taking my hands off the wheel or looking away from the road. Be sure to set the dimmer to very low at night too.
Attached Thumbnails Weight Limit on Tach?-dscf3749.jpg   Weight Limit on Tach?-dscf3750.jpg   Weight Limit on Tach?-dscf3755.jpg
PsychoRallye
21
Feb 17, 2019 06:08 AM
RobbyD
Jan 29, 2019 01:22 PM
Suspension Products
Oct 1, 2015 11:53 AM
EVMini
Sep 28, 2015 10:20 AM
Sep 28, 2015 09:13 AM
