Interior/Exterior Removal of dashboard vent grille
Old Jul 14, 2008 | 06:33 PM
sornstein's Avatar
sornstein
After a brief encounter with a deer, the windshield shattered into a million small pieces. Many of these pieces fell down the defroster vent and the larger vent located on the dashboard. Can anyone tell me how to carefully remove the large vent grille so that I can attempt to vacuum out the small pieces of glass in the HVAC ducts?
Old Jul 14, 2008 | 07:22 PM
chaseabryant's Avatar
chaseabryant
You will have to remove the upper dash pad, on either side of dash, when you open your doors, you will see two small panels, they pry off, and there will be two screws holding the dash pad on on either side. Unscrew them, and your dashpad/grille will lift right off.
-Chase
Old Jul 15, 2008 | 07:52 PM
AutoXCooper.com's Avatar
AutoXCooper.com
How did the MINI make out? Got Pics?
Old Jul 15, 2008 | 08:23 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
btw, if you have a late model R53, then the dash is held on by about a zillion more screws and thingys than the early model ones. I once tried to remove my 2005 dash---and the old "how tos" were written for earlier models. They are totally misleading. I even talked to my dealership techs, and *they* hate later model dash repairs...and they are getting paid to do it!!
Good luck with the glass removal.
cawwwtun
May 3, 2016 08:03 AM
wkp1219
Nov 13, 2015 07:52 AM
Aug 27, 2015 03:18 PM
greekzilla
Aug 23, 2015 03:44 PM
