Suspension KW V2 vs JIC CROSS coilover
Old Jul 10, 2008 | 10:34 PM
Doc Cooper's Avatar
Doc Cooper
I know most NAM members prefer JIC Cross c/o.
Any thoughts on KW V2? I had a good experience on E46 M3. I probably wont be tracking the car, maybe once a year..
On E46 M3, Ive tried TCKline (koni shocks /linear springs), PSS9 (POS ), KW v2. Out of three, TCKline and KW V2 was great.
On the MCS, knowing that it is a totally different car, but still those coilover should provide similar characteristic improvement over stock form. Just wanting to get some opinions.
Thanks.
Old Jul 11, 2008 | 08:48 AM
JDR's Avatar
JDR
This won't answer your question...but
I would go with a cheaper option since you aren't planning to track that often.
I have the V1s and love them, a lot of people like the H&Rs which are even cheaper.
Old Jul 11, 2008 | 01:51 PM
jproz's Avatar
jproz
As a contrary post to the above poster, I went with the "wallet" approach and bought the CROSS.
Very happy with them thus far (though only had them installed within 30 days or so).
Note: I also don't have track requirements; tis is my daily driver.
I don't have experiance with the others .
Old Jul 12, 2008 | 07:02 AM
KLZ's Avatar
KLZ
I had V2 on my R53 and it was great ( I went to track with it 2 times a month in the summer), my competition V2 for my R56 is here waiting for install next week... couldn't wait
Old Jul 12, 2008 | 08:25 AM
Doc Cooper's Avatar
Doc Cooper
thanks for the input.... ya.. i dont know if i'll ever go to a track (i really should try once or twice).. yes.. spirited driving and it is my daily driver. I need to do more research and ride in cars that has different setup.
Old Jul 12, 2008 | 11:10 AM
fongaroos's Avatar
fongaroos
when you say the H&Rs do you mean that a lot of people just went with H&R springs and oem shocks? or does H&R make a full coilover setup for the r56?
Old Jul 12, 2008 | 11:22 AM
JDR's Avatar
JDR
coilovers
Old Jul 12, 2008 | 12:19 PM
CFMINI's Avatar
CFMINI
I have KW Comp 2's now on one of my MCS's and m7 Coilovers on the other one. I have also had Bilstein PSS9's on both cars at one point in time. The KW's are great on the track but not so much on the street. The Bilstein's were good, but the m7's are better IMHO for a mostly street driven car and canyon runner with occasional (3-4 times a year) track days. Never drove a car with Cross coilovers.
Old Jul 12, 2008 | 09:46 PM
Doc Cooper's Avatar
Doc Cooper
Thanks for your info. Cross does cost around $1900.... having said that, it isnt a cheap mod but going with cheaper/different setup and not liking it can cost me a lot more. Ive done that before and it sucks... lol
Old May 10, 2009 | 01:44 PM
bonehead04's Avatar
bonehead04
Probably answered somewhere on another thread (but there a million of them), but aside from street/track characteristics, which give the biggest drop?
Old May 10, 2009 | 02:18 PM
Dead Ringer's Avatar
Dead Ringer
from reading a ton of threads and different opinions, I also went with the M7's. For the money they provide the bext overall comfort and when when its time to go to the track, you can "stiffen" them up perfectly. But I think they are the best overall value and provide great ride quality..
Old May 10, 2009 | 11:19 PM
dunphyj's Avatar
dunphyj
well actually i would recommend something that isn't "on the market"....
i have custom ordered some modified Koni coilovers with custom TCKlein Springs (the Koni's are obviously revalved for the springs). i'm not sure exactly how the other coilovers are set up on the market, but i know how the lowering springs are... most keep a near stock setup with a spring bias towards the rear so the car is a little more likely to pop it's rear around for cornering at the limit... i did some research and had a few people who have raced mini coopers in the past say that this is fine for street and lowering springs but if you're going coilover route you should actually get a slightly different setup.
now to this point i only know all this in theory because my Coilovers are to arrive this coming thursday. but i have driven in an E46 M3 with these exact same "brand" name coilovers and honestly, the spring rates are high, but the custom valving makes it (the M3 at least) IMO the best possible street coilover kit available that's easily adjusted and usable on the track. now if you want i'll keep you updated as to everything and how it goes.. i plan to get plenty of pictures, and i'll probably start a new thread about them... i also plan corner balancing them to try and get the most out of them.
The kit cost me $2200 and comes with:
-TCKlein Springs, (for my set) 450lb/in Front, 350lb/in Rear Linear springs all around
-Koni Coilover shocks w/ threaded body and custom valving
-Vorshlag Camber Plates
-Double adjustable Compression and Rebound
Made specifically for the R56 (and can be made to work with JCW GP cars by just asking to swap out the R56 camber plates for R53 ones...)
so yeah... just letting it be known that there is another option that could potentially be the perfect middle ground between JIC Cross and KWs... i have only driven one car with KWs on them and that was Helix13's Shop car R56 (very nicely done btw, it's quite amazing setup they have) so i'll have that as a reference to compare to KW coilovers... honestly don't know about Cross but i know they're higher spring rates than most C/O kits... so could be a direct comparison for Cross as well...
Old May 10, 2009 | 11:37 PM
spinned's Avatar
spinned
Doc Cooper where did you find the Cross COs for $1900. The cheapest I have seen is around $2,300.
Old May 13, 2009 | 12:26 AM
Doc Cooper's Avatar
Doc Cooper
I had TCKline coilover for my E46 M3 - 500/500 LOVED the setup. It was one of the best setup ive ever had for that car.... PERIOD.. comfort and performance was a nice balance...
Old May 13, 2009 | 02:28 PM
dunphyj's Avatar
dunphyj
here here!
Old May 19, 2009 | 07:55 PM
Chief_Charlie's Avatar
Chief_Charlie
You must be very special dumphyj !
Found tckline's website and contact info and sent a message inquiring about the suspension package you described in your post above. Received the following response:
This would be a custom hand built system based on Koni Sports. We built a similar system for one of our cars. It has separate rebound and compression adjustments. Allow 6-8 weeks for it to be built, cost will be around $3100.00 for the springs, height adjusters, and shocks. Camber plates would be extra.
We do not have any other options.
Given that the price did not include the camber plates which were included in your listed $2,200 "kit" , I'd say you are very special to the folks that sold it to you. More than I can afford..............
So I went with the Cross Coilovers. Got them from Waylen @ Way Motor Works.
Old May 19, 2009 | 08:42 PM
leebo's Avatar
leebo
Hi Charlie,
Let us know how you like the Cross Coilovers. I'm getting ready to install some on my GP on June 6th. I'm interested to know what you think of the difference between the GP suspension and the Cross setup.
Lee
Old May 20, 2009 | 01:15 PM
txwerks's Avatar
txwerks
We love KW's...
For your application, I would say V2's would be the way to go, with custom valving and springs to match what you would be looking for...
Old May 20, 2009 | 03:30 PM
dunphyj's Avatar
dunphyj
Gee that sux tcklein threw u around like that... I wish I knew u were looking for more info there, I would have given u my contact dan's number
Old May 21, 2009 | 12:50 PM
masterd78's Avatar
masterd78
MANIAC
I have the Cross Coilovers and love them. I ride pretty slammed all the time, and they are great for what is expected when you are LOW!!
Old May 23, 2009 | 07:03 AM
Chase's Avatar
Chase
KW ftw
Old May 24, 2009 | 12:19 AM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
Cross w/Swift springs FTW
Old May 24, 2009 | 03:22 PM
Doc Cooper's Avatar
Doc Cooper
more info on Swift springs with cross setup....
I have cross coils .. forgot what rate springs...
Overall its ok setup.. i think i have to fine tune with better tires and cambers and control arm links perhaps..
WHat are your thoughts on control arm links...
RIchard Nguyen
Sep 14, 2016 11:43 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
gnhovis
Sep 28, 2015 10:56 AM
