Suspension Suspension Push
Old Jul 8, 2008 | 07:33 PM
Dano67's Avatar
Dano67
Suspension Push
Hello,
So I just put on some new Yokohama S tires and I have noticed that the car seems to push thru the turns when I am on the gas. As soon as I let of the gas it stops pushing. I have an Alta 19mm bar on the back set to the middle hole. I did not notice this with the stock runflats. Car is a 2002 S. Any help would really be appreciated.
Old Jul 8, 2008 | 07:40 PM
AutoXCooper.com's Avatar
AutoXCooper.com
How many miles are on the new tires? May just need some more scuffing to stop pushing.
Old Jul 9, 2008 | 01:16 AM
groovetini's Avatar
groovetini
you could also adjust your rear bar for a little more oversteer.
Old Jul 9, 2008 | 06:16 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
That is normal for any front wheel drive car, pretty much no matter what parts and settings you have. Although, the effect is less pronounced with all the stuff I have. Try snapping the throttle off after the apex, be ready to correct & reapply gas. I might also sugest approaching the turn faster than you normally would so that you can apply the brakes quickly and dive the car forward to load the front tires. Then let off and make your turn, you can change how the car takes the turn by where you apply and let off the gas throughout the turn.
It takes practice.
Old Jul 9, 2008 | 08:47 AM
Dano67's Avatar
Dano67
h
The tires only have about 200 miles on them. I tried going in faster, but it seems as I accelerate out of the corner the front of the car drifts towards the outside of the turn. They just did an allignment, Could they have changed some setting? Sorry really dont know anything about suspension setup.
Old Jul 9, 2008 | 09:03 AM
gnatster's Avatar
gnatster
Check tire pressures.
Ask for a printout of the alignment so you can see what the settings are.
Old Jul 9, 2008 | 09:07 AM
Dano67's Avatar
Dano67
s
I will call and get them.
Old Jul 9, 2008 | 09:22 AM
OldRick's Avatar
OldRick
At 200 miles, your tires may still have mold-release stuff on the surface (making them slippery) and they have not been heat-cycled many times, thus the rubber will be softer than it will become.
Please put another 200 miles on them, and report back...
Old Jul 9, 2008 | 09:32 AM
Dano67's Avatar
Dano67
s
Should be able to get those miles in today on the freeway cloverleaf---- My offical testing grounds
Old Jul 9, 2008 | 02:28 PM
meb's Avatar
meb
All of the above can cause this condition; alignment, new tires AND, if these tires are significantly stickier than your previous tires, they can cause the lower front control arm bushing to deflect more which migt add more understeer - push.
I would also check and experiment with tire pressure. too little or too high pressure can cuase this too...but I would expect this to even out if the front and rear pressure is the same.
Old Jul 9, 2008 | 02:37 PM
Mezspeed's Avatar
Mezspeed
You might want to make sure your outer tie rod ends are in good shape. Knowing the age of your MINI, if you haven't replaced them yet, it's surely not far down the road from needing it. Depending on their condition, worn tie rod ends can make it near impossible to get the front end right in alignment and ultimately proper handling.
Old Jul 9, 2008 | 02:55 PM
Dano67's Avatar
Dano67
I will check the tie rod ends and see if they need to be replaced
Old Jul 10, 2008 | 05:06 AM
meb's Avatar
meb
...please check the LCA bushing as well since this will cause the very condition you described. As an aecdote, the Powerflex bushings I've been using for nearly 100,000 miles allow me to throttle my way thru a turn...the car just goes where it's pointed. Not even new stock LCA bushings will allow this.
tie rods are very easy to check and replace - I replaced these three times in 133,000 miles...just because, not because these were worn.
Old Jul 11, 2008 | 10:06 AM
Dano67's Avatar
Dano67
So I drove angeles crest to Mt. Wilson yesterday and the tires seem to be sticking better. What is a LCA bushing? Any sugestions on which tie rods and ends to use?
Old Jul 15, 2008 | 12:25 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Note that road surface type and tire/road temperature can effect tire grip too.
LCA stands for Lower Control Arm. However, the car only has one front control arm, and only one bushing on that arm - two ball joints too, so I normally call it the front control arm bushing. Although a picture is not neccessary, I need to give my fan(s) some more art.
I think the OEM tie rods are good enough, but I'm also interested in stronger replacements if anyone finds any.
Old Jul 17, 2008 | 05:44 AM
meb's Avatar
meb
Nice drawing!!! Contact Aurora for custom rod type tie rods - outer, not inner. I have 133,000 on my car now and the inner tie rods are still tight as hell. I compared movement carefully with the subframe removed against a new unit...after about 15 minutes of playing and testing all sorts of movements I decided the stock units were in great shape...perhaps I should find a block of wood to knock on
Old Jul 17, 2008 | 12:06 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I'm glad you like it. I might make a whole series of diagrams depicting various part locations. I've been tossing the idea around with Ancient Mariner since yesterday. It will be mostly for entertainment, but they will be accurate. My drawings mesh the cartoony style of a small child with bad handwriting and the knowledge of a mechanically oriented enthusiast who has seen and felt these parts first hand.
If your stock tie rods lasted to 133,000 miles, then I'm sure mine will too. I was just curious if there were any other options. I'll look into what Aurora has to offer.
Old Jul 17, 2008 | 12:16 PM
ofioliti's Avatar
ofioliti
I like them too. Keep them coming. I have the Bentley manual but your schematic "cartoons" are better.
Old Jul 19, 2008 | 12:42 AM
silversmoke06's Avatar
silversmoke06
I do like them. You cant deny the boys got style.
Old Jul 21, 2008 | 05:48 AM
meb's Avatar
meb
I have drawings of suspension geometry, but as I am a computer moron, I cannot get my drawings into NAM
Old Jul 31, 2008 | 08:56 PM
markldriskill's Avatar
markldriskill
Please ignore this post.
Filmy
Jun 28, 2016 08:58 AM
ej
Nov 17, 2015 09:21 PM
RDSJCW
Sep 16, 2015 03:54 PM
Suspension Products
Sep 10, 2015 11:46 AM
Suspension Products
Sep 2, 2015 10:32 AM
