Navigation & Audio Auxiliary Audio Input...
Old Jul 1, 2008 | 04:55 PM
lordgrinz's Avatar
lordgrinz
Where should it be installed in the car? Factory location would be where? Plus what kind of cord do I need to hook the Sirius unit I have to the auxiliary input?
Old Jul 1, 2008 | 06:31 PM
Btwyx's Avatar
Btwyx
It wasn't a factory option, but a dealer option. The jack is sited in the side of the glovebox. The jack is a 1/8" (3.5mm) mini jack, so it needs one of those on one end, and whatever the Sirius has on the other.
Old Jul 1, 2008 | 09:42 PM
rkw's Avatar
rkw
The glovebox is the standard location where a dealer will install the jack, but you can install it anywhere. Many of us install it in the cubby at the bottom of the center console.
Old Jul 2, 2008 | 07:44 AM
lordgrinz's Avatar
lordgrinz
The glovebox seems a weird place to put it, what good would it do there? I do like the cubby idea, the flip down plastic plate might be a good spot to put it.
Old Jul 2, 2008 | 07:58 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Advantages of the glovebox location:
1) an mp3 player on shuffle is outta sight there.
2) it's quite easy to route an audio cable from that location, down the inside of the downtube or under the dash panels, to wherever you might have you accessory mounted. I have a very clean wiring setup for my GPS using this approach.
Which the underside of the cubbie door is a convenient location, it's also going to leave an exposed plug and some exposed wiring, if you're going for a "clean" look.
But put it anywhere you want.
Just answering the "what good would it do there?" question...
Old Jul 2, 2008 | 08:28 AM
hunsingeruk's Avatar
hunsingeruk
I thought there is a standard aux port near the ash tray and cup holder
Old Jul 2, 2008 | 08:36 AM
BlimeyCabrio
Not on 1st gen MINIs. Some of the late 2006 cars (like mine) and all later cabrios (I think) came from the factory with the glovebox aux input standard...
Old Jul 2, 2008 | 10:06 AM
rkw's Avatar
rkw
I see that you have (or ordered) an R56. Yes, you have an aux port under the toggle switches. You posted your question in the 1st gen forum.
Old Jul 4, 2008 | 01:19 PM
lordgrinz's Avatar
lordgrinz
Well I got the Auxillary Input Installed, then I figured out that I couldnt find a clean way to install the Sirius radio. I just didnt like anything I could think up, but the Aux Input does make a nice way to hookup an MP3 player. I guess my only option for Sirius is to pay for the factory option, which I think is WAY over priced.
Filmy
15
Jun 6, 2023 06:27 AM
gar56
Nov 15, 2016 06:41 AM
Filmy
Sep 7, 2015 08:27 PM
Ntety
Sep 2, 2015 08:39 PM
