Gas Mileage and Tire Sizes
Old Jun 28, 2008 | 05:51 PM
eenieMini's Avatar
eenieMini
OK After reading most of the tire size/choices I have made a decision on new affordable shoes for Moe... my last decision is on the size... the manufacture plus size recommendation is 215/40/17 but most of the posts here suggest 215/45/17. So, question which tire will give me the best gas mileage or am I better off keeping the stock size 205/45/17? I wanted a fatter tire for looks more than for anything else.. I'm going to get Yokohama Avid H4S
Moe has the white S-lights
Old Jun 29, 2008 | 12:21 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Better gas mileage will be with slightly higher tire pressures than usual.
Using tires that are less wide makes more sense as do tires that weigh less.
215/40-17 are for performance and handling with stiffer sidewalls. They can cost more and weigh less. 205/45-17 is a little better at mpg. You can´t really go much narrower with a 17¨ wheel on a MINI. To get a narrow tire you´d need a narrow rim like 15x6 or 16x6.5. Stock 15¨rims are 15x5.5 and will take a 185/65-15 tire which is less good for handling but good for mpg.
Old Jun 29, 2008 | 02:09 PM
ChiliXer's Avatar
ChiliXer
narrower tires reduce your rolling resistance which improves the mileage.
A larger overall diameter would probably help as well with the way the mini is geared. Although the car will say the mileage is worse because it assumes everything based retaining stock diameter (so smaller will say its better). Both of those sizes wont be too far off the stock sizing, the 45 profile being a bit over and the 40 a bit under.
Old Jun 30, 2008 | 05:42 PM
ChiliXer's Avatar
ChiliXer
I saw this the other day. http://www.discounttiredirect.com/di...foTireMath.jsp
That seems like one of the better explained calculators I have seen before. It should help out anyone that doesn't want to try and do their own calculations.
Old Jul 1, 2008 | 03:52 PM
eenieMini's Avatar
eenieMini
Thanks everyone!
kazyn
Oct 25, 2019 02:34 PM
Southern Marylander
Jan 14, 2019 06:05 PM
SunnySideUp
R57 :: Cabrio Talk (2009+)
Aug 26, 2015 01:16 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
