R55 help on resetting mpg on computer
Old Jun 27, 2008 | 06:37 AM
drno's Avatar
drno
as many times as i have read the owners manuel i can't find out how to reset the computer to zero for mpg at fill up ( or for that matter any of the functions that read out on the panel of the spedometer)
Old Jun 27, 2008 | 06:48 AM
ngweibing's Avatar
ngweibing
u just press it a few seconds longer till its get to ZERO..
Old Jun 27, 2008 | 07:59 AM
Otra's Avatar
Otra
If you don't have the Nav, which I do not, you must scroll through the options on the On Board Computer (OBC) by pressing the little button on the end of the blinker stalk...going past Set/Info...when you get to the item you wish to zero out...as ngweibing wrote - hold the button in for a few seconds longer.
As for resetting your trip odometer - that's even easier...the little black stick like button that sticks out from the OBC itself next to the trip odometer.
When I first got this second generation MINI, I felt like a complete idiot when it came to all this pressing of buttons and *****...now it's old hat.
Old Jun 27, 2008 | 09:08 AM
jonabad's Avatar
jonabad
I prefer to use the radio display to reset the miles per gallon independently as using the stalk control will reset all of those stats.
Old Jun 27, 2008 | 09:20 AM
dlpruk's Avatar
dlpruk
Do you have a "menu" button on yours"? If so, just switch on, press it and twiddle the selector **** to highlight whatever you want to change and then press the reset button that's highlighted.
Old Jun 27, 2008 | 09:27 AM
Arthuralda's Avatar
Arthuralda
Bad Jona,
How do you Re-Set with the Radio?
Old Jun 27, 2008 | 09:32 AM
Otra's Avatar
Otra
The button does not reset all the values unless you choose for it to - at least mine doesn't.
I just find it easier to use that button because I can do it faster.
Old Jun 27, 2008 | 02:35 PM
drno's Avatar
drno
yes i do have a menu button and i have used the scroll **** and a reset light is on the screen but where is the reset button?
Old Jun 27, 2008 | 08:10 PM
jonabad's Avatar
jonabad
its one of the ones directly below the display, where the presets would be when you're in radio mode.
Old Jun 29, 2008 | 08:45 AM
drno's Avatar
drno
thanks--it was easy
Old Aug 2, 2008 | 05:47 AM
Anthony314's Avatar
Anthony314
is there an online manual or "how to" that displays all the icons with the OBC? I mean, besides the manual that comes with the car.
Old Aug 2, 2008 | 10:54 AM
ftttuhzbmcs's Avatar
ftttuhzbmcs
I have the pdf versions of with or without NAV owner's manuals. I'm pretty sure they will assist with this thread.
Old Aug 3, 2008 | 04:32 AM
Anthony314's Avatar
Anthony314
wow! Is there any way I can get a copy of the one without the NAV?
Old Aug 3, 2008 | 05:23 AM
Otra's Avatar
Otra
The manual comes with all the info - including the Nav, I believe but never bothered to check... If you want it, you can either PM me with an email address for me to send it to you as an attachment - or you can contact MINI via the Owners Lounge and they will email it to you. You choice.
Old Aug 3, 2008 | 09:24 PM
ftttuhzbmcs
My 2008 Clubman manual pdf files are distinctly different. Anthony314, just send me a private message with your e-mail or just have otra do it. It is no problem at all. I'm a work unti midnight and when I get home, I can send both files.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
madmix
Oct 5, 2015 09:58 AM
dutchhome
Sep 30, 2015 07:17 AM
TurboMike
New York/New England
Sep 28, 2015 08:12 PM
