R50/53 MPG won't display
Old Jun 24, 2008 | 05:51 AM
05Greenie's Avatar
05Greenie
MPG won't display
When scrolling thru the events on the tach I noticed that the Avg mpg has been diplaying 99.9 for 2 weeks now. All the other display's are operating normally. Anyone know why?
Also does anyone else have a severe engine drop off when the A/C is on? I know some power loss will occur, but the amount I have seems secessive.
Old Jun 24, 2008 | 06:02 AM
MINIFVR's Avatar
MINIFVR
Im not sure about your MPG display issue. Whether the power loss that occurs when you turn on the AC is 'excessive' is subjective, so to some it may not seem to bad and to others it may seem severe. Since we are dealing with a 4 banger the power loss is pretty significant, IMO. I never use the AC for that reason alone.
Old Jun 24, 2008 | 06:04 AM
Apple's Avatar
Apple
It is a pull on my 03, but barley noticed it on the 08?
Old Jun 24, 2008 | 06:14 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
99.9 MPG?! What is your secret?
There might be a problem with the sensor that reads how much gas passes into the engine. So your range and fuel dial still work though?
The power loss with a/c can be severe if you run it full blast. I always have it set at 1-3 bars, if any.
Old Jun 24, 2008 | 08:58 AM
Btwyx's Avatar
Btwyx
Do you ever reset the average MPG?
I could imagine if you went on long enough without resetting it, you could overflow the math involved which would not make it happy.
Old Jun 24, 2008 | 09:38 AM
05Greenie's Avatar
05Greenie
No, is that something I should be doing? If so, how do I reset it?
When it wa soperating correctly the mileage displayed was 31.3mph, is that accurate and is 31.3 typical for an 05 R50 with 79k miles on it?
Old Jun 24, 2008 | 09:43 AM
ChiliRedS's Avatar
ChiliRedS
To reset hold the the button on the turn signal stalk down for a few seconds once you have the Avge MPG displayed.
Old Jun 24, 2008 | 09:46 AM
ngweibing's Avatar
ngweibing
thxs for the info.. . i was having same problem too
Old Jun 24, 2008 | 09:49 AM
05Greenie's Avatar
05Greenie
Ya...thanks.
Old Jun 24, 2008 | 04:19 PM
Btwyx's Avatar
Btwyx
Did that solve it? I have vague recollections of hearing of this before.
If you don't reset the MPG, you'll see the MPG since forever, which may or may not be useful to know. If you do reset it, it'll tell you the MPG since the last reset. I reset it every tank.
On the other hand Quentin did seem to give me very strange readings once when I reset it between fillups. I never worked out exactly what, but I only ever reset it when I filled up, and reset the trip odometer at the same time, and it seemed to behave itself.
Old Jun 24, 2008 | 06:06 PM
ChiliRedS's Avatar
ChiliRedS
No problem
Old Jun 25, 2008 | 04:17 AM
05Greenie's Avatar
05Greenie
The reset was sucessful.
Thanks again for the very useful information.
This site rocks!
Old Jun 25, 2008 | 04:33 AM
MINIFVR's Avatar
MINIFVR
Just cut the roof off your car and then you won't need the AC, some of us have done it already.
PsychoRallye
21
Feb 17, 2019 06:08 AM
navybsn
Oct 5, 2018 04:42 PM
Sep 30, 2015 11:24 AM
Sep 30, 2015 10:58 AM
Sep 29, 2015 12:11 PM
