Aftermarket Wheels / Bolts & Orig. Spare Question
Old Jun 23, 2008 | 05:19 PM
atl05mca's Avatar
atl05mca
Dear NAM;
Searched this forum but didn't find the exact answer I'm looking for.....
Basics: 2005 Mini R50, 15" Holies, non run flat Contis, std. donut spare
The Plan: Upgrading to Konig wheels w/ non run flat tires; per tire dealer, I have to install a std. stud / nut mounting
Questio: Will the std Mini donut spare work the stud / nut setup ?
Thanks in advance !
Old Jun 23, 2008 | 09:29 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by atl05mca
Dear NAM;
Thanks in advance !
Spare tire should work with aftermarket wheel stud setup. Often nuts have a variety of styles from acorn to tapered to match the wheel being used.
Are you saying that the tire vendor is telling you that you cannot use the stock wheel bolts for the Konig wheels? You'll need wheel studs and nuts?
I'm not sure if that is true. Most times you can use the stock wheel bolts with aftermarket wheels.
Old Jun 25, 2008 | 09:00 AM
atl05mca's Avatar
atl05mca
Thanks for the reply...
Per dealer, the factory wheel bolt has a flat mounting surface on wheel, while aftermarket wheels have a chamfered mounting hole.....
Old Jun 25, 2008 | 09:38 AM
glnr13's Avatar
glnr13
uhhhh sounds like your dealer doesnt know what he's talking about. there is no doubt that your lug bolts are chamfered/cone seated
kazyn
Oct 25, 2019 02:34 PM
SosoMINI
Nov 22, 2015 03:17 PM
blackie
Aug 23, 2015 08:44 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
