Aftermarket Wheels / Bolts & Orig. Spare Question
Dear NAM;
Searched this forum but didn't find the exact answer I'm looking for.....
Basics: 2005 Mini R50, 15" Holies, non run flat Contis, std. donut spare
The Plan: Upgrading to Konig wheels w/ non run flat tires; per tire dealer, I have to install a std. stud / nut mounting
Questio: Will the std Mini donut spare work the stud / nut setup ?
Thanks in advance !
Thanks in advance !
Dear NAM;
Thanks in advance !
Thanks in advance !
Are you saying that the tire vendor is telling you that you cannot use the stock wheel bolts for the Konig wheels? You'll need wheel studs and nuts?
I'm not sure if that is true. Most times you can use the stock wheel bolts with aftermarket wheels.
SosoMINI
Nov 22, 2015 03:17 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
