R50/53 Shifter Noise
Old Jun 12, 2008 | 08:49 PM
Wini The MINI Cooper's Avatar
Shifter Noise
When I shift gears, I hear a squeaking noise. At times, it can be harder than others to shift gears, requiring a good bit of work. The dealer says it is normal and the fluid is lifetime. What can I do to make it shift better and squeak less? 02 MCS w/ 36k.
Old Jun 12, 2008 | 08:53 PM
Ancient Mariner's Avatar
Ancient Mariner
Is the squeaking when you move the shift lever, or the clutch pedal? Or something else? If it's the shifter, it may be that the cables need lubrication.
Or is it coming from the clutch/transmission. Need some details, Wini.
Old Jun 12, 2008 | 09:00 PM
It is just the shifter, shifting in and out of any gear makes a squeaking noise. the clutch feels like it has a few more years left and works fine.
Old Jun 13, 2008 | 12:57 AM
Ancient Mariner
Take a look at the picture here:
http://www.realoem.com/bmw/showparts...85&hg=25&fg=05
the cables (5 & 6) may need lubing, or the socket where the shift lever goes into the box.
Old Jun 13, 2008 | 01:38 AM
silversmoke06's Avatar
silversmoke06
Mine thumps going from first to second but i figured that was normal
Old Jun 13, 2008 | 04:03 AM
DaveTinNY's Avatar
DaveTinNY
I get a little of the thumping effect too - really it all depends on the speed I move the shift lever into the next gear. If I take it really easy, it's a smooth transition. If I go more rapidly, I can feel the shift. I have, in haste, ground the gears a few times over the life of this '05 MINI and it's always mortally embarrassing for me but from what I understand, not too bad on the tranny. I sure hope not.
wildwestrider
Dec 27, 2015 08:20 PM
Mazarin
Electrical
Dec 7, 2015 08:23 AM
67morris
Dec 1, 2015 12:53 PM
unxpectederror
Oct 22, 2015 12:16 PM
Rainforest_Elf
Sep 16, 2015 10:13 AM
