adjusting parking brake
Old Jun 8, 2008 | 01:16 PM
freeskier's Avatar
freeskier
my handbrake is not grabbing as well as i would like it to, is there a way to adjust it? thanks
Old Jun 8, 2008 | 01:24 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Yep. Unclip the boot from the console and lift it up. You'll see a nut (I think 10mm, but not sure) on the front of the handbrake unit, below the handle. The appropriate procedure is to jack up the rear of the car, and adjust this nut such that there is NO drag on the rear wheels at "zero" clicks and "one" click... but then starts grabbing at the 2nd click. I found that I could take a TON of slack out of mine and it made a huge difference in the amount of stopping power available at 3-4 clicks.
Old Jun 8, 2008 | 02:59 PM
toddtce's Avatar
toddtce
Good to know for those who have fit my rear Wilwood parking brake calipers also. Due to the change in the leverage mechanism on the caliper I've found the handle needs about six clicks to be effective. While sure there was/is a way to take out some of that slack I've personally not done so.
Old Jun 8, 2008 | 03:02 PM
BlimeyCabrio
Cool Todd... by the way... to remove slack, you tighten the nut (turn clockwise)... which basically pulls more of the stud through (more exposed stud = less slack)...
Old Jun 8, 2008 | 03:57 PM
freeskier's Avatar
freeskier
ok sounds good, and what is the best way to move the boot? thanks
Old Jun 8, 2008 | 04:54 PM
freeskier's Avatar
freeskier
ifound the adjustment appratus, now what is the best way to check my work? i would prefer the brake as tight as possible.
Old Jun 8, 2008 | 06:03 PM
BlimeyCabrio
Re-read my first reply.
1) lift rear of car
2) pull brake one click
3) try to turn rear wheel. Should be no brake drag
4) pull brake to second click
5) you should start to get some drag on the wheel now
6) you can tighten it as much as possible while still having NO DRAG on the first click.
7) done (don't forget to take the car off the jack before you try to drive... )
Old Jun 8, 2008 | 09:21 PM
freeskier's Avatar
freeskier
excellent thanks, it was just not bighting before
Old Jul 11, 2008 | 03:41 PM
OSUBeaver's Avatar
OSUBeaver
Glad I found this post, I just installed the TCE rear kit and I'm looking to ADD slack to the system. I'm assuming following your directions in reverse will do that, I'll give it a shot tonight!
Old Mar 23, 2026 | 05:52 AM
dougpmc@gmail.com's Avatar
dougpmc@gmail.com
TO adjust handbrake on my2011 mini cooper R60 countryman, remove cover behind handbrake console on centre console in back of car., to do this , unclip circular plastic plate with small blade and unscrew 3 x torx screws, pull cover off, look under top of hole and you will see at the very top a threaded bar with a 10mm nut, you will need a 1-2" long 10mm socket , with extention bar to either tighten or loosen hand brake cable. DOUG.
Old Mar 23, 2026 | 05:55 AM
dougpmc@gmail.com
Doug
ebowling
90
Aug 4, 2019 09:15 AM
khumpert
Nov 30, 2015 11:48 AM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
