R50/53 Remote Keyless Start? Possible with 2002-2006 MINI?
Is it possible to install a remote engine starter in the cooper (2002-2006)?? has anyone successfully accomplished it OR known someone who has installed a remote starter system and it worked fine? Thanks
Don't think so, the car won't start unless the key is in the ignition (computer chip).
I was thinking about same thing. I have a manual 6 speed and it won't work?
there are ways to make it work. I will not go into that as a google search should be able to answer this, as some of it becomes a safety issue, i.e. clutch switch and people leaving cars in gear.
I have done it on another car that had a chip in the key and a 5-speed.
But it can be done
But it can be done
When I had a remote starter installed in my other car. I had to buy another key and this do-hickey to put the key in (it hides under the dash, and I destroyed the key part of it so no one can steal the car). Basically the do-hickey has a wire that leads up to wrap around the ignition so that the car "thinks" the key is in the ignition. As for the manual tranny thing, I know it can be done, but I'm not sure how.
Aug 7, 2015 09:51 AM
tippin
Aug 5, 2015 08:43 AM
