R52 Any cabrio amateur radio ops?
Old Jun 6, 2008 | 06:03 AM
wbarnhill's Avatar
wbarnhill
Coordinator :: Upstate MINIs
I was curious if anyone has an amateur radio in their cabrio, and if so, how was the antenna mounting handled? Just something I thought of recently...
Old Jun 6, 2008 | 06:07 AM
BlimeyCabrio's Avatar
BlimeyCabrio
I'm not a ham.... but a few folks are now mounting CB whips on their tow hooks on the rear, using a mirror mount, with good results. No idea how well this will work for your rig. Only other option I've heard is a glass-mount antenna on the windshield.
Old Jun 6, 2008 | 06:26 AM
wbarnhill's Avatar
wbarnhill
Do you know if that affects the PDC?
Old Jun 6, 2008 | 07:32 AM
BlimeyCabrio
Yep... PDC goes nuts when in reverse with the tow hook mount on. Only downside I've found to it.... but don't know of a better option... and unplugging the offending PDC sensors isn't an option - that will yield a continuous tone, too.
Old Jul 27, 2008 | 03:54 AM
Storm Chaser's Avatar
Storm Chaser
Ham radio in mini
Hi, Just found the thread. I have a lot of ham gear in my cabrio. A hi Q bug catcher mounted on the rear tow hook. A mast stabelizer on a bracket that bolts inside the trunk lip. The 2 meter and 440 ant is on a matching bracket on the other vertical lip of the trunk door. All bolts are inside the door so no holes will show when all is removed. I am also running 500 watts to an ameritron. All equipment is in the trunk well over the battery. W5IG is my call, good luck. Storm chaser. LEE
Old Jul 27, 2008 | 05:59 AM
BlimeyCabrio
Would LUV to see detailed pics of your setup, brackets, mounts, etc.!
Old Jul 27, 2008 | 09:02 PM
Storm Chaser
pix
If you will send me a pm with your Email I will send you some pix. They are too big to put on the line.
bahman
Feb 14, 2016 10:29 AM
pglgp1292
Oct 5, 2015 06:47 PM
ahorvath
Oct 3, 2015 01:13 AM
simo711
Oct 1, 2015 05:36 AM
