Suspension Dinan suspension lower in the back? Or did I do something wrong?
Old Jun 4, 2008 | 10:47 AM
groovetini's Avatar
groovetini
So, I just installed the full stage 3 (springs struts camber plates) on my 02 MCS. and now that it's back on the ground, it looks like the front was barely lowered, and the rear is over and inch lower. Did I do something wrong?
Old Jun 4, 2008 | 10:56 AM
Tüls's Avatar
Tüls
Turbius Maximus
Things might need to settle... worst case, Front springs could be upside down...
pics?
Old Jun 4, 2008 | 05:05 PM
groovetini's Avatar
groovetini
Front spring were installed by a dealership, so I'm more likely to trust them over me.
pics:
Rear:
Front:
Old Jun 4, 2008 | 05:15 PM
Intense's Avatar
Intense
252whp 200trq RMW style
My Eibachs sat a little lower in the rear than the front. Not saying the Dinan is supposed to, just saying it might be designed that way.
Hopefully someone that has the Dinan can help out. Do you have camber plates in the front?
Old Jun 4, 2008 | 08:36 PM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Some set ups like the Racing Dynamic lowering springs. That I ran would lower front only 1" while the Back 1.5". The changed moved the stants from about 3 Deg Rake to the front to almose flat about .5 deg
Old Jun 4, 2008 | 08:38 PM
groovetini's Avatar
groovetini
not sure if it comes through in the pics, but it looks like 1.5" down in the rear, and nothing the front.
Old Jun 5, 2008 | 07:32 AM
cooldaddy's Avatar
cooldaddy
camber plates raised the front a bit due to increased "stack up" height... ?
Old Jun 6, 2008 | 01:08 PM
jblow's Avatar
jblow
The front camber plates in the S3 Dinan package do raise the front slightly; however, this is offset with the slightly shorter springs. I recently installed the S3 package on my car as well - the rear is definitely lowered more than the front - I spoke with Dinan and told that is to be expected. The car may settle over time - I don't believe that the rear on mine is quite that low; however, I do have a slight variance in ride height left to right on the back of the car after lowering... That said I have been very happy with the package so far.
surfblue
Oct 24, 2018 01:20 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
