R52 Annoying noise from inside rear sidewalls
Old May 31, 2008 | 03:18 PM
MassMini's Avatar
MassMini
My '05 cabrio (built Sept '04) makes a very annoying rattle noise which seems to come from inside both rear seat sidewalls. It's most noticeable at slow speeds with the top down - doesn't matter whether the windows are up or down. The driver's side noise is right by my left ear.
Anyone know what makes this noise? Or even better how to fix it?
Old Jun 1, 2008 | 08:06 AM
StLouieLo's Avatar
StLouieLo
Is it the rear seat belts? Sometimes they rattle around if they are not fully retracted or the buckle can beat against the side panels & get quite noisy.
Lois
Old Jun 1, 2008 | 08:15 AM
big howe's Avatar
big howe
I have the same thing. I actually take the seat belt clips and put them up behind the loop at the top of the seat, but that's not the issue. The rattle is definitely behind the rear speakers somewhere(in my car at least), I've had it to the dealer twice, of course I get the "we fixed it" , no they didn't. Mines real bad over Botts dots(those raised road dots in Cali). I've yet to take it apart myself. If you find an answer, please let us know.
P.S. Mine's a Nov 04 build.
Old Jun 1, 2008 | 08:54 AM
StLouieLo's Avatar
StLouieLo
My Cabrio was a Sept 04 build. It had 2 issues with the rear side windows. The mechanism on both sides froze & was scratching the windows in an eliptical pattern both times. I don't recall hearing a rattle from back there, however. Do you have any scratches on the rear side windows?
Lois
Old Jun 1, 2008 | 09:12 AM
big howe's Avatar
big howe
Well, for me, the rear side windows had a lurching behavior the dealer fixed. All of the windows squeal horribly when it's hot out. Dealer says they fixed that too.
Old Jun 1, 2008 | 09:36 AM
MassMini's Avatar
MassMini
Lois
I have had both rear windows replaced under warranty for the "crescent shaped scratches" problem. This included installation of some updated internal clips as I remember.
Old Jun 1, 2008 | 09:40 AM
MassMini's Avatar
MassMini
Lois
It definitely not the seat belts banging against the rear side walls. (That's a different annoying noise)
My noise is coming from inside the rear walls and sounds a bit like a glass on plastic. Or styrofoam on plastic.
Old May 28, 2015 | 07:43 AM
wrxnofx's Avatar
wrxnofx
Resurrecting an old thread here. Did you find the cause of the rattle? My wife's car has a rattle of some kind on the driver's side that sounds like it's in where the rear side speaker is.
Old Jun 17, 2015 | 07:20 AM
Did you check to make sure the slack on the seat belt is not hitting the rear side panels. Pull the belts to the top and use the belt slider as the holder. Keep the belts tight when not in use.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
W0TM8
Dec 19, 2019 07:50 AM
TJANK
Aug 24, 2015 06:11 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
