Suspension lowering questions...
Old May 31, 2008 | 01:20 PM
matty125's Avatar
matty125
IF I purchase springs like the Eibach sport springs to lower my R56 S w/ sport package will I have to change anything else? Can I simply have the springs installed and have a tire company align my front end? What is this talk of camber and stuff. I just want a SAFE low ride, and I do not want any odd tire wear-out of the deal.
Old May 31, 2008 | 02:10 PM
trackster's Avatar
trackster
It depends on how low the springs drop the car . You will get a bit more negative camber front and rear but the key is how much . At most you may get a bit more aggressive inner rear tire wear . As the back of the car is relatively lite and does not do a lot of work it should not be much of a problem. The best thing to do is to search others that have your set up and see how they made out over time .
Old Jun 2, 2008 | 08:49 AM
sunman's Avatar
sunman
There has been quite a bit of discussion about this and this thread may address some of your questions. Good luck..
https://www.northamericanmotoring.co...d.php?t=136521
smdmini
Oct 7, 2019 06:05 AM
massmini03
Sep 18, 2015 05:40 PM
hydouken
Sep 15, 2015 05:49 AM
Accessory Products
Sep 9, 2015 10:29 AM
Sep 2, 2015 11:15 AM
