R56 TPMS and Valves
Old May 29, 2008 | 06:13 PM
ckranert's Avatar
ckranert
TPMS and Valves
Does anyone know where I can get the sensors and valves? I have only found one site that has the sensor and one that has the valves. I want to replace my stock wheels (getting 17" MOMO S-Five black ) and want to ensure I get the best price on these parts. Thanks!
Old May 29, 2008 | 06:30 PM
minimark62's Avatar
minimark62
Try this: http://cgi.ebay.com/ebaymotors/BMW-M...spagenameZWDVW
I bought mine from here (Tirerack ) - They're OEM and came with both sensors and valve stems.
Old May 29, 2008 | 07:12 PM
ckranert's Avatar
ckranert
Thanks so much! This is exactly what I needed.
Thanks again!
Old May 30, 2008 | 04:20 AM
sbiel's Avatar
sbiel
I am not sure that the sensors will move to your new wheels, but when I upgraded from 15" to 17" rims, I have the tire shop move the TPMS sensors to the new rims. Just needed an o ring kit (about $5 each).
works fine !!!
Old May 30, 2008 | 05:04 AM
VelvetFoot's Avatar
VelvetFoot
I bought my TPMS sensors from the same place and installed them myself.
This helps:
http://beru.com/download/produkte/mo...tung_tss_e.pdf
Old May 30, 2008 | 05:36 AM
ckranert's Avatar
ckranert
Were there any additional steps when you put the tires back on the car or was it "plug and play"? The PDF says I may have to calibrate the sensor and the car.
Old May 30, 2008 | 05:42 AM
VelvetFoot's Avatar
VelvetFoot
Plug and play. No errors.
But, your manual tells you how to reset the TPMS.
Old May 30, 2008 | 05:43 AM
VelvetFoot's Avatar
VelvetFoot
A thing that I saw was that you have to think about which of the two differently shaped washers to use.
Old May 30, 2008 | 04:13 PM
Prost's Avatar
Prost
So, the set they sell is all I need to install for an OEM MINI wheel? Nothing extra? A set of 4 sensors?
Old May 30, 2008 | 04:49 PM
minimark62's Avatar
minimark62
Yep - everything is included. I had mine installed at the tire dealership. The calibration procedure is in the owner's manual. Takes about 2 minutes.
Mark
freckles81
Jan 15, 2017 06:33 AM
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
Emnotek
Sep 29, 2015 07:37 AM
