R50/53 Look what we have here...
Old May 20, 2008 | 10:02 PM
Revolution Mini Works's Avatar
Ok, here is the next little project on the RMW table......
well, there is much more than this but we can't spill the beans on everything as we like to keep some things in suspense Please feel free to guess what we are going to do with this.
Old May 20, 2008 | 10:09 PM
bumble's angel's Avatar
bumble's angel
It is obviously a butterfly mold. You are going to make decorative hood ornaments. I don't think it will work on my car but it would look good on some cars.
Old May 20, 2008 | 10:17 PM
MLPearson79's Avatar
MLPearson79
A creatively balanced pulley?
Old May 20, 2008 | 10:28 PM
you are onto me, even though I put it on a CP piston box
Old May 21, 2008 | 12:34 AM
Ancient Mariner's Avatar
Ancient Mariner
You missed the cool colored bangle braclets behind the mold. Or hoop earrings?
Old May 21, 2008 | 12:36 AM
silversmoke06's Avatar
silversmoke06
will the winner get a free one if they guess it.?
Old May 21, 2008 | 12:59 AM
Drillslinger's Avatar
Drillslinger
Well, if they're larger diameter than the std ones... 1.8 or 2.0??
Regardless, we'll be watching
Old May 21, 2008 | 05:32 AM
minimarks's Avatar
minimarks
1.8 RMW centercaps?
Old May 21, 2008 | 05:35 AM
PGT's Avatar
PGT
got a melted one I can use as a paperweight? guess I should email Gintani for that
Old May 21, 2008 | 05:39 AM
CFMINI's Avatar
CFMINI
Its an aluminum billet cupholder with a specially CNC machined "well" to hold excess coffee that will spill as you zoom around corners in your MCS that has lots of RMW parts? Jan, this was MY idea, you beat me to the market AGAIN!!
Old May 21, 2008 | 06:19 AM
we are getting warmer
more too it though
Old May 21, 2008 | 06:20 AM
wow,,, some great ideas here
maybe we can come up with something for your coffee table conversations
It will RMWs first NON performance product
Old May 21, 2008 | 06:38 AM
PGT's Avatar
PGT
it's an ashtray
Old May 21, 2008 | 06:51 AM
Originally Posted by PGT
it's an ashtray
if used improperly.... yes.... definitely an ashtray
Old May 21, 2008 | 06:56 AM
GOTCURVES's Avatar
GOTCURVES
critical part to a "stroker" project? Don't go there Jan I've had a similar project idea just haven't had the time, but apparently you have.
Old May 21, 2008 | 06:58 AM
we have plenty more projects going on, this is just one of them that we are now ready to talk about
Old May 21, 2008 | 07:21 AM
ScottinBend's Avatar
ScottinBend
Non-performance.............?
You're not turning into the new PU are you........................
Old May 21, 2008 | 07:31 AM
mauberley's Avatar
mauberley
Someone had to fill the void.
Old May 21, 2008 | 09:06 AM
HighLife4136's Avatar
HighLife4136
Expansion tank cap
Engine oil cap
Power steering cap
Old May 21, 2008 | 09:34 AM
MUShadd's Avatar
MUShadd
you forgot gas cap
Old May 21, 2008 | 09:41 AM
Haggardsk8er's Avatar
Haggardsk8er
It looks like something I need... as long as they come with wrist pins
Old May 21, 2008 | 01:10 PM
GOTCURVES's Avatar
GOTCURVES
They probably will, but I wouldn't use them in my car unless they come with a custom counter weight system!
Old May 21, 2008 | 01:12 PM
JGS's Avatar
JGS
I was thinking "Hemi-Cooper"
Old May 21, 2008 | 01:20 PM
xbook's Avatar
xbook
Is this possibly a twin cam setup that we see the start of?
Old May 21, 2008 | 01:42 PM
Nitrominis's Avatar
Nitrominis
As it is a domed piston the diameter is not the point of interest rather the compression ration. Lets see if you increase the compression ration slightly you can lower the blower speed and thereby by lower the heat created by boost pressures. Not to mention keep the M45 in a reasonable RPM speed. You then pick up more bottom end torque and still have good top end. And if you machine the piston dome configuration to the combustion chamber there is even more hidden power. Old tricks on racecars, new trick for a MINI? Then if you offset grind the crank change the rod length and piston pin height…why stop at a 2.0 ? Do we see a 500whp Mini engine in the future ?
