R50/53 Look what we have here...
Old May 21, 2008 | 02:59 PM
  #26
big howe's Avatar
big howe
It's an Espresso machine. No, no wait, it's a Tri-State Fragistat. Flux capacitor? I got it, I got it, it's a left handed limited edition, hand signed by Jan, bottle opener!
Now what do I win??????
Old May 21, 2008 | 03:14 PM
  #27
Tüls's Avatar
Tüls
Turbius Maximus
ha ha this is good stuff....
Old May 21, 2008 | 03:19 PM
  #28
BlimeyCabrio's Avatar
BlimeyCabrio
A double-sided nut-rest. For one to rest their nuts on. From either side.
I prefer cashews... but any nuts would probably work.
When resting one's nuts on the RMW double-sided nut-rest, at least 10lbft of torque can be gained on the butt dyno. Fifteen if you hum a Culture Club tune at the same time.
Old May 21, 2008 | 05:10 PM
  #29
ScottinBend's Avatar
ScottinBend
Remember............................non-performance
Old May 21, 2008 | 05:57 PM
  #30
big howe's Avatar
big howe
What, I didn't win yet......?
Ok Ok Ok, it's a key iradiateathingamobober. It guarantees the wings on the key face the right direction when you start the car. No? OK, it's the magic piston, cousin to the magic 8 ball, you shake it and it helps you name your Mini
RMW sure is reaching into new markets and territory here. Some of the vendors better watch out, Jan is blazing new ground.
Old May 21, 2008 | 06:16 PM
  #31
Revolution Mini Works's Avatar
this might add a little more haze
or clarify.... let's all look very very closely and what do you see
  #32
Eurothrasher's Avatar
Eurothrasher
Nicer than some of the Hemi Heads Ive seen
Originally Posted by Nitrominis
As it is a domed piston the diameter is not the point of interest rather the compression ration. Lets see if you increase the compression ration slightly you can lower the blower speed and thereby by lower the heat created by boost pressures. Not to mention keep the M45 in a reasonable RPM speed. You then pick up more bottom end torque and still have good top end. And if you machine the piston dome configuration to the combustion chamber there is even more hidden power. Old tricks on racecars, new trick for a MINI? Then if you offset grind the crank change the rod length and piston pin height…why stop at a 2.0 ? Do we see a 500whp Mini engine in the future ?
Great job with that jug head, better design than some of the hemi heads Ive seen.
Old May 21, 2008 | 06:21 PM
  #33
big howe's Avatar
big howe
I see 8 pipes!!!! I got first dibs on a ride in the V8 Mini!!!!!!!
I do have to admit the stucco work looks top notch in the second pic.
  #34
Eurothrasher
Is this for a V8 Mini ?
One has a port for an 02 sensor, nice, usually only see these on grand national stock cars......
Old May 21, 2008 | 06:26 PM
  #35
LOOK VERY VERY CLOSELY............ they are different sizes... trying to give hints.... No V-8s in sight
all our custom race headers come this way with the O2
Old May 21, 2008 | 06:28 PM
  #36
too late, we already have passed that a long time ago
Old May 21, 2008 | 06:31 PM
  #37
Jhud's Avatar
Jhud
i see nice spackle work on the wall...
Old May 21, 2008 | 06:36 PM
  #38
big howe's Avatar
big howe
I already know what it is
Because Jan let me use it already. It IS the magic piston, i shook it and helped it me name my car "Suck My Wake"
Old May 21, 2008 | 06:37 PM
  #39
Jhud's Avatar
Jhud
does a totally new engine count as "performance"?
Old May 21, 2008 | 06:39 PM
  #40
we sell only MINI parts
Old May 21, 2008 | 06:40 PM
  #41
Nitrominis's Avatar
Nitrominis
anti reversion tubes or adjustable collectors
Old May 21, 2008 | 06:42 PM
  #42
Eurothrasher
NIce TIG Welds too on those collectors, is one for a MINI and the other for a MINI S ?
Old May 21, 2008 | 06:44 PM
  #43
hey.... someone found the kitchen
Old May 21, 2008 | 06:58 PM
  #44
big howe's Avatar
big howe
What does a kitchen have to do with a V8 Mini?
Old May 21, 2008 | 07:03 PM
  #45
bumble's angel's Avatar
bumble's angel
So with your new butterfly molds, you are making quad-umbrella stands for patio furniture. Looks like you are going with an entire patio furniture market.
And this means you are making grills as well.
Do I smell a name change?
Palo Weber?
Old May 22, 2008 | 05:25 AM
  #46
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
Mystery Part
It has to be a right-handed Kenutin Valve.
You just have to make sure it isn't in the Gangla Mode after installation, if so do the following:
Insert a 5/8 in socket and speedhandle into the manual drive shaft and rotate at twice the normal speed until the timing pin engages.
Old May 22, 2008 | 06:57 AM
  #47
ScottinBend
And I thought you said a non-performance part.................
Old May 22, 2008 | 08:26 AM
  #48
Tüls's Avatar
Tüls
Turbius Maximus
Retro Encabulated Regurgitator!
Old May 22, 2008 | 01:05 PM
  #49
Nitrominis's Avatar
Nitrominis
we have plenty more projects going on,
Don't we all
Old May 22, 2008 | 04:18 PM
  #50
Haggardsk8er's Avatar
Haggardsk8er
Smoke Stacks!!!!
