R50/53 Slightly rough start
Old May 19, 2008 | 08:27 AM
cmyk's Avatar
cmyk
EDIT: Turns out this is normal. Phew!
I'm about 5500 miles away from service #2 (22,500 on the ODO) on my 2006 MCS.
For the past week, starting the car every morning takes an extra crank. It takes a second or two before the engine starts to run smoothly. It seems like the issue happens regardless of the car being warm or cold.
Is this a case of the fuel/air filters getting old because I'm so close to a service, or could this be something else?
Old May 19, 2008 | 10:34 AM
evilduck's Avatar
evilduck
I have/had the same issue (I'm at 22,800 miles on my 03 MCS). I've done a few things that have improved the startup, but haven't eliminated the need to crank twice during long periods of inactivity.
Changed plugs: idles much better and smoother
Cleaned out intercooler: had some oil in the intercooler - cleaned it out and car started much easier
Injector cleaner: I've run about half a tank thus far and it's seeming to help a lot.
One of theories here is that when the injectors are dirty they leak a little. This leaking "wets" the plug and causes you to crank a couple of times to start things up. This may be true, but I'm not sure. What I do know is that the car is starting much easier now (about 50% one crank and 50% two).
Good luck!!!
ED
Old May 19, 2008 | 10:45 AM
MUShadd's Avatar
MUShadd
I had a similar issue. The car just did not want to start on that first crank whenever it had set for a few hours. I actually dropped my octane from 93 to 89...despite the recommendation, and it starts like a champ now. I even got 2mpg better average, and i'm saving 10 cents a gallon at the pump, lol.
since ur so close to service, have the dealer check this out for you. it seems a few people have conquered this issue by the dealer doings some update to the ecu.
iggi
18
Feb 9, 2026 01:00 AM
maniacalmorgan
Jan 1, 2020 11:20 AM
blackie
Jan 18, 2017 09:56 PM
Marco Guardado
Sep 15, 2015 01:22 AM
Dsinkster
Aug 17, 2015 03:24 PM
