R50/53 Oil Pressure/Temp gauge questions for an R53...
Old May 15, 2008 | 11:49 AM
kriation's Avatar
kriation
For those of you that are using either/both gauges, with an electrical sensor, where did you mount the sensor? Also, since we have a canister housing over the oil filter, where did you tap into for the reading?
TIA!
Old May 15, 2008 | 01:07 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
For the oil pressure, I used a tee that came with the Promini cluster. For oil temp, I drilled and tapped the center of the oil filter housing (inside the 36mm hex). Unlike trying to hang a bulky electric oil pressure sender that would have to be removed in oder to remove the canister, the temp sensor is small enough that once the wires are removed from it, the socket fits over the hex without interference from the sensor. I get good oil temp readings there as well.
For coolant temp, I placed my sensor in the block drain plug, behind the starter. Since I have Nav, I didnt have a temp gauge at all. This had worked beautifully, tracking the OBD-retrieved temp within a couple degrees.
Old May 15, 2008 | 01:59 PM
kriation's Avatar
kriation
Awesome! Thanks for the input. Are there any oil galley locations that are worthwhile to tap into for oil temp?
Old May 15, 2008 | 03:15 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I have a drain plug adapter for oil temp. The wire has a disconnect for when it's time to change the oil, a recent addition. I hear that it is best to read bulk oil temp, as that gives a better indication of average oil temp. My oil pressure sender is in place of the stock sender, which I've disconnected and cut away. It does not effect any computer functions as it was only used to light the oil indicator.
Old May 15, 2008 | 03:36 PM
nascar mini's Avatar
nascar mini
Also,measuring temp at the pan,closer to main bearings is a more accurate reflection of oil temp as opposed to measuring it at the oil filter block near the cooler.
Old May 15, 2008 | 03:54 PM
Guest's Avatar
Guest
I also use a drain plug adapter for the temp sensor (Oil coming down from the bottom of the engine will be the hottest). For the Pressure sensor I use the Helix Tapless adapter (HMS 2050 - $31.95). It just fits on to the stock pressure sender and allows you to hook up your own sender.
Old May 15, 2008 | 03:59 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I had my pressure sender mounted with the stock sender on an elaborate T fitting. However, the combination of the excessive weight of this assembly and the poor roads in this area caused apparent metal fatigue in the T fitting. It leaked.
Old May 16, 2008 | 09:39 AM
Greatbear's Avatar
Greatbear
The oil filter mount actually has an undrilled/untapped hole ideal for use as an oil pressure or temperature tap point, it would have to be removed from the engine and drilled to accomodate a sensor. I found there was little difference in the oil temp between reading it at the pan versus at the oil filter. It's actually a couple degrees hotter at the filter, since the airflow across the bottom of the pan tends to cool this area somewhat at speed, and the oil picks up some heat from the block on it's way to the filter. The oil is cooled (and often warmed as well in cold weather) after passing through the filter by the oil cooler.
Old May 16, 2008 | 12:31 PM
ridingfar's Avatar
ridingfar
I went the route of installing a Madness oil cooler kit and used the temp and pressure sensor ports machined into the adapter plate.
I also used electric gauges; the pressure sensor is on a 17" braided hose that allowed me to remote mount it inside the ABS brake module "compartment" on the passenger side of the firewall.
The gauges are 2 1/16" AutoMeter short sweep in the Craven NavPod mount above the speedo/tach cluster on the steering column.
Observations:
- Oil pressure and temp feedback is a Good Thing
- Constant 180 degree oil is nice
- It takes 7 or 8 miles of driving to warm 5 1/2 quarts of oil to 180 degrees, even when using an oil cooler thermostat (the cooler and lines add a quart to the system)
Happy Mod'ing!
Old May 16, 2008 | 02:25 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
What kind of thermostat do you use for the oil cooler, ridingfar? I have a Canton 200ºF thermostat that blocks 100% of the oil from going to the cooler untill it gets to 200º.
Old May 17, 2008 | 01:17 AM
ScottRiqui's Avatar
ScottRiqui
Interesting thread. I would have thought that the R53 engine would already have all of the necessary holes present, since the Chrono-equipped cars have oil temperature, oil pressure, and the oil pressure "idiot light" from the factory.
Old May 17, 2008 | 04:21 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The factory oil temp comes out of the drain plug with a disconnect. I have heard about it.
Old May 17, 2008 | 06:17 AM
ridingfar's Avatar
ridingfar
I used a PermaCool 180 degree unit that blocks 95% of the oil going to the cooler until the oil warms and it opens up. So far its never hit 200 degrees even after a long drive and then taking a 15-20 MPH tour of some high end development for 15 minutes. I've been impressed and satisfied at the added ability to hold steady oil temps.
I'll shoot some pics and post them later today.....
Old May 17, 2008 | 08:16 AM
ScottRiqui's Avatar
ScottRiqui
I have the Chrono Package on my car, and there's no sensor in the drain plug. Perhaps there's a dealer-installed auxiliary gauge package that uses a sensor there - that might be what you're thinking of.
Old May 17, 2008 | 09:40 AM
ridingfar's Avatar
ridingfar
Oil Cooler Install to get Gauges
Pics of the completed install:
Attached Thumbnails Oil Pressure/Temp gauge questions for an R53...-_mg_6787.jpg   Oil Pressure/Temp gauge questions for an R53...-_mg_6788.jpg   Oil Pressure/Temp gauge questions for an R53...-_mg_6789.jpg
Old May 17, 2008 | 09:41 AM
ridingfar's Avatar
ridingfar
One More
One more pic:
silence2-38554
Nov 12, 2015 09:39 AM
ShadyCoop
Aug 24, 2015 06:05 AM
tylewis
Aug 18, 2015 06:53 AM
dchang0
Aug 10, 2015 03:37 PM
