Navigation & Audio Revisit: SIRIUS Antenna?
Old May 7, 2008 | 01:56 PM
JGS's Avatar
JGS
Will the best install be to use the car antenna for the Sirius Satellite Radio; or, will I need to figure out a routing to put my magnet on the roof?
Can you do both with the existing car antenna? I would still like to be able to use the car radio.
Old May 7, 2008 | 02:31 PM
spfdhed's Avatar
spfdhed
IMO the cleanest and easiest is to connect to the in-car satellite antenna under the passenger seat. I have used it for my aftermarket XM radio for >6 months without any problems and I get excellent reception (even in my garage).
Old May 7, 2008 | 06:05 PM
JGS's Avatar
JGS
can both your in-car radio and the XM make use of the antenna?
Old May 7, 2008 | 06:15 PM
kimoz's Avatar
kimoz
I went w/Sirius. I have the type that can move from mini to boombox. I ran the antenna wire though the dashboard up the driver side and the main magnetic piece just sits on dash no need to make it stay there forever. The base unit sits inside cupholder nicely. IMHO - Sirius offers more sporting events.
Old May 7, 2008 | 07:02 PM
JGS's Avatar
JGS
Well; let's see:
Sirius radio - mount, power, antenna
Nuvi GPS - power, mounted on speedo
iPod - power, mounted....I am not sure where
Where does it all end!!!....the wires; the wires......
Old May 7, 2008 | 07:18 PM
JGS's Avatar
JGS
Oh; and I forgot...
The Radar Detector;
Well, maybe not....not an "S" model.
Old May 7, 2008 | 07:29 PM
rob_gendreau's Avatar
rob_gendreau
And the Scanguage, and the Gtech meter (accelerometer)....
Seriously, is there an aftermarket power buss or something that one can use to neatly hook up 12v power to all of these gadgets without millions of cig lighter plugs??
Old May 8, 2008 | 07:55 AM
acmdude's Avatar
acmdude
Just finished my install of an XPressRC using the sat antenna connection under the front seat and it works beautifully. The signal strength I am getting is the same as I get in my Land Rover which uses the mini-XM antenna on the roof. I live in Central Oregon. Using the built-in sure makes life easier.
Old May 8, 2008 | 10:04 AM
n2hcky's Avatar
n2hcky
I will be installing the same unit when my Clubman gets here.
What and where did you get your ant. wire?
What kind of mount did you do?
Old May 8, 2008 | 11:18 AM
JGS's Avatar
JGS
Does the connection under the seat let you share the XM radio and car radio on the built-in car antenna.
This is probably second nature if you are actually doing it, but I don't have my car yet. Will both radio systems still work if you tag this underseat connector?
Thanks!
Old May 8, 2008 | 11:35 AM
gasmini03's Avatar
gasmini03
Oh; and I forgot...
The Radar Detector;
What do you mean not an "S" model no Radar Detector needed ? I wish you could have told that to the cop that pulled me over for speeding. My non S MINI just happened to be slowing down to 90!
Old May 8, 2008 | 11:48 AM
JGS's Avatar
JGS
Gasmini;
So it sounds like you have plenty of power with the non-turbo car?
I have vacillated on this selection, but couldn't justify the extra $.
How does it cruise at 80 - 85 mph?
Old May 8, 2008 | 03:10 PM
gasmini03's Avatar
gasmini03
Gasmini;
Just under 4000rpm and hardly seems like its working hard. It all depends on how you want to drive the car.
Old May 8, 2008 | 07:27 PM
acmdude's Avatar
acmdude
I ordered the cable from Citrus Cables in Florida. It's a 50 ohm, 6ft cable with a male connector (to attach to the underseat antenna wire) and a 90 degree female connector to connect to the XM dock. It's Product ID 2100 on their web site.
I used the Kuda mount 092445 and then used the swivel mount that comes with the XpressRC. Hope that helps.
Old May 8, 2008 | 07:29 PM
acmdude's Avatar
acmdude
Thanks!
Yes, the various antennas are separate so you can use Tuner for AM/FM or AUX for XM radio. Connecting to the Sat antenna under the seat doesn't affect AM/FM
Old May 8, 2008 | 07:31 PM
JGS's Avatar
JGS
Terrific!
Thanks for all the information.
GregoryK
Dec 14, 2015 01:34 PM
1ZigZag
Oct 6, 2015 07:08 PM
pglgp1292
Oct 5, 2015 06:47 PM
simo711
Oct 1, 2015 05:36 AM
