Suspension Need some advice about rims tires and specers
Old May 6, 2008 | 10:24 PM
amg56aaf's Avatar
amg56aaf
I am getting ready to but a set of Stern 17 ST-8 (http://www.maxspeedperformance.com/x...ome.php?cat=54) and the center hub bore is 73mm I was trying to see if I will need a hub adaperter to center th wheel up. I can not seem to find the hub bore size, I want to go with the black Palo Uber lugs and Black Valve stems but I did not know if I should order the ring or not? Also what size tire should I run on them they are 17" x 7.5 215/40/1 with a H-sport spring set on the car already. Last question sorry to who ever started this post I just thought it would be a good place to ask should I run a spacer the wheel offset is 45mm? Thanks to everyone in advance
Got to love my G.W. Bush Stimulus package it has already been spent . and some!!!
PS. please PM with your reply they come to my phone Thanks
Attached Thumbnails Need some advice about rims tires and specers-wheel-3.bmp   Need some advice about rims tires and specers-wheel-2.bmp
Old May 6, 2008 | 11:37 PM
glnr13's Avatar
glnr13
MINI hub bore is 56.1mm. best to get a hubcentric ring
just a heads up, the palo uber lugs have a bad rap.
215/40/17 is a good size, some have also run 215/45/17 but you *might have some rubbing. lastly, should you run a spacer? well, that's up to you.
Old Nov 26, 2008 | 09:49 AM
gmhl10's Avatar
gmhl10
When you say the MINI hub bore is 56.1mm... do you mean R53 or R56?
Old Nov 26, 2008 | 09:52 AM
glnr13's Avatar
glnr13
both are 56.1
Old Nov 26, 2008 | 10:00 AM
gmhl10's Avatar
gmhl10
both are 56.1
Looks like I'll need a hub ring then.
Thanks for the quick reply.
Waszak
Oct 21, 2017 05:55 PM
schwac2
Jun 14, 2016 04:06 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
TOMSR53
Aug 26, 2015 10:18 AM
