Drivetrain OBD Scanner
Old May 2, 2008 | 07:00 PM
Unit One's Avatar
Unit One
OBD Scanner
"Service Engine Soon" light came on in my 06MCS this morning... stopped by Autozone and their scan yeilded a fault with the #1 O2 sensor... have spoke with the Dealership and made an appointment to get car in (still under warranty afterall)... but now I really would like to have an OBD scanner... one that shows the code descriptions... and has the capabilities to update (via internet)... and the ability to print...
and one that hopefully is in the $150 range...
Any and all feedback will be much apreciated...
Old May 2, 2008 | 07:06 PM
bad venge's Avatar
bad venge
scangaugeII
Longboard Mini's Avatar
Longboard Mini
http://www.scangauge.com/
LB
Old May 2, 2008 | 09:25 PM
Minidrivr's Avatar
Minidrivr
The scangauge doesn't show descriptions like you requested. Only the code number.
Old May 2, 2008 | 10:03 PM
roaduscarnivorous's Avatar
roaduscarnivorous
what about this: http://new.minimania.com/web/Item/NM.../InvDetail.cfm
Old May 3, 2008 | 06:34 AM
MINIdriver85's Avatar
MINIdriver85
I have the ScanGauge II, but what about the DashDyno?
http://www.dashdyno.net/
Old May 3, 2008 | 07:15 AM
jhiggs26's Avatar
jhiggs26
Here's a nice and simple code reader.
http://www.peakeresearch.com/emx.htm
Jeremy
Old May 3, 2008 | 11:30 AM
SumWon's Avatar
SumWon
Hard to beat an Actron:
http://www.actron.com/
They range from cheap and easy all the way up to WOW!
I have used them for years.
Old May 3, 2008 | 11:35 AM
daflake's Avatar
daflake
Got one of these and it works very well.
http://www.amazon.com/Equus-3130-Dia...9839978&sr=8-1
It also comes with a great manual and software to help decipher the codes that are thrown.
Old May 4, 2008 | 07:47 AM
herbie hind's Avatar
herbie hind
sears automotive online has decent ones . mine gives descriptions and freeze frames certain info at the time the code was thrown .
Old May 4, 2008 | 11:16 AM
TRuTH's Avatar
TRuTH
Do they also check other warning lights. My ABS, Flat-tire and Traction control light come every time I hit a bump and then stay on until I turn the car off.
Also, I have an OBD II for my 2000 Pontiac will it work
Old May 4, 2008 | 05:37 PM
herbie hind
sears? don't know i suppose if it tosses a code ...
Old May 4, 2008 | 05:45 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Why not just go to your local Auto parts store, a number of chain stores have the for free loan. You pay for the scanner with a credit card and have 60 days to return it for a full refund. Check your Sunday paper, you may find an AD with just such an offer.
No need to buy one.
Old May 5, 2008 | 12:54 PM
daflake's Avatar
daflake
No need to buy one.
Because it isn't the right thing to do. You open the product and use it then the dealer has to sell it as an open item at a loss. In a way, you are stealing from the vendor. Best just to borrow one from an auto place or buy one. They are not that expensive anymore.
Old May 5, 2008 | 12:56 PM
daflake's Avatar
daflake
Yes, it will work on both cars (should on the 2000....) However, it does not check lights. These units only check codes in the ECU, not other on-board computers. So, your other problem will have to be troubleshot.
Old May 5, 2008 | 01:06 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I have a ScanGaugeII and it's been worth every penny I paid for it. The peace of mind is priceless when a code comes up, you know why (coz you modified that part last month...) and you clear it.
Also the real time display of 4 measures of your car's performance is valuable, or at least entertaining.
Don't steal from retailers, don't be cheap and borrow someone else's. Go and buy one.
Old May 5, 2008 | 01:15 PM
MINIdriver85
I have one too, but might change it for a DashDyno, which also can be used as datalogger and realtime dyno. Plus, you can hook up a wideband controller to the analog imput and have the AFR shown on the display with the other things, saves you another gauge.
Old May 5, 2008 | 01:24 PM
checkmate2006's Avatar
checkmate2006
ScangaugeII FTW! I have one and just like the Doc above said its worth every single penny.
Old May 5, 2008 | 01:30 PM
moodylewdd's Avatar
moodylewdd
My SES light has come on the last few times I have driven my car off of the hill my parents live on. First time I reset it with the battery-hold down on brakes trick. It reset...until I drove down the hill again. Second time I took it to AutoZone, and he read the scan...showed up as the #1 O2 sensor also. They told me to replace my plugs and wires as well as the sensor. Told my handy dandy mechanic, after freaking out that the sensor alone was going to run me 199.99, and my car only has around 57,000 miles on it (yes I am way out of warranty just from age). He just told me to run the highest octane fuel (which is 93 around here-been running slightly less than that-cause I have to drive 30 miles for the 93 octane-so dont bust me out on it ;-). Anyway, no more SES light! The blasted light has not come back on yet, even after driving up and down the hill several times.
Try that if you havent all ready, maybe it will save you a trip to the dealership. (Or just go for a free o2 sensor...)
Oh, yeah and you can buy a really nice OBD2 scanner on eBay for hardly anything, just buy from a reputable seller!
Finhead
Electrical
Apr 12, 2019 04:05 PM
PsychoRallye
21
Feb 17, 2019 06:08 AM
navybsn
Oct 5, 2018 04:42 PM
RocketUSA
Sep 15, 2015 07:45 AM
mimaal
Sep 4, 2015 09:09 AM
