Suspension R56 lowering springs: options and specs
Old Apr 30, 2008 | 01:43 PM
dajiggalo's Avatar
dajiggalo
This thread will focus on all available spring options for the R56. I will post the brand name, type (progressive or linear), spring rate, drop (in inches), part number, and MSRP. I prefer not to post the actual sale prices in order to avoid a price war between the vendors. Also, I will not cover coil-overs in this thread in order to maintain simplicity and uniformity. If any vendors have the actual spring rates for the listed products, please PM me so that i can update the information. Thanks!
Old May 9, 2008 | 05:17 PM
dajiggalo's Avatar
dajiggalo
Eibach Pro-Kit
Brand: JCW (John Cooper Works) Springs
Part #: *
MSRP: $420.00
Drop F: 0.4"
Drop R: 0.4"
Spring type: linear
Spring rate:
Brand: Eibach Pro-Kit
Part #: 5705.140
MSRP: $349.00
Drop F: 1.2"
Drop R: 1.2"
Spring type: progressive
Spring rate: **
Brand: H&R Sport Springs
Part #: 50452
MSRP: $329.00
Drop F: 1.4"
Drop R: 1.4"
Spring rate: **
Brand: Mach V Technic Springs
Part #: 05828
MSRP: $239.00
Drop F: 1.25"
Drop R: 1.25"
Spring rate: **
*note, three different springs are available depending on your vin number (in order to determine the relative weight of your vehicle), thus different part numbers. This does not change the price and overall ride height reduction however. See your dealer for details.
**progressive springs will actually vary in spring rate according to the amount of compression, thus no single spring rate will be listed.
Old May 9, 2008 | 06:15 PM
ThumperMCS's Avatar
ThumperMCS
Mach V's are progressive as well
Old May 9, 2008 | 09:47 PM
Guest's Avatar
Guest
As are the H&R's. The only Linear Springs for the R56 are the TSW's, which haven't been released yet.
Cross Coilovers are Linear, available in almost every spring rate imaginable. Megan Coilovers are Linear, Also available in almost every spring rate.
Both sets of coilovers have integrated front camberplates.
Old May 9, 2008 | 10:43 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
H&R Sport Springs
Some additional info for H&R Sport Springs (green finish)-
Note, the R56 2007+ hatchback springs are Silver/Grey!!
Lowering rates and fitment guide:
07+ Hatchback Cooper : 1.4" front, 1.4" rear. #50450
07+ Hatchback Cooper S: 1.4" front, 1.4" rear. #50452
02-06 Hatchback Cooper S: 1" front, .75" rear. #50416-2
01/02-03/02 Hatchback Cooper: 1" front, .75" rear. #50416-1
04-08 Convertible: 1.4" front, 1.4" rear. #29192-1
Old May 10, 2008 | 05:35 AM
Bhatch's Avatar
Bhatch
For what it is worth, TW variant 1/2/3 coilovers are Progressive front and linear rears rate is 230 lbs/in
http://www.kw-suspension.com/en/30_P...pe=all&zeile=6
Old May 10, 2008 | 02:42 PM
dajiggalo's Avatar
dajiggalo
Note, we are not covering coil-overs in this thread, only springs
Old May 12, 2008 | 09:41 PM
wimsaab's Avatar
wimsaab
I using eibach pro kit, great quality riding, much better handing, a bit more stiff...and not to low for everyday driving...
Old May 14, 2008 | 02:03 PM
Wake|MCS's Avatar
Wake|MCS
So the lowest drop spring available as of now for the R56 are the H&R's?
Old May 15, 2008 | 05:47 AM
dwebber18's Avatar
dwebber18
I just got my H&R springs for the R56. I'm going to get them put on hopefully this weekend or the next after I get my Sway bar in. I'll let everyone know how it goes after I do.
Old May 15, 2008 | 06:20 AM
loadtoad's Avatar
loadtoad
Originally Posted by dwebber18
I just got my H&R springs for the R56. I'm going to get them put on hopefully this weekend of the next after I get my Sway bar in. I'll let everyone know how it goes after I do.
I ordered mine earlier this week along with some lower control arms. Assuming they get here they will be going on Saturday. If they don't who knows when I will have time to put them on!
Old May 15, 2008 | 06:35 AM
BDBMCS's Avatar
BDBMCS
I've beeen thinking about using the JCW springs on Koni adjustables. Just wondering if anyone knows if the springs will fit the perches? Or do you use the perches from the stock shocks?
Old May 15, 2008 | 06:47 AM
checkercoop's Avatar
checkercoop
Is it true that simply putting lowering springs on stock suspension will make the suspension die out quicker? I really want to get rid of the gap, but its not worth having to replace the whole suspension early
Old May 15, 2008 | 07:10 AM
dwebber18's Avatar
dwebber18
Also, anyone thats thinking about getting H&R springs check out tirerack.com cause they have them for $199
Old May 15, 2008 | 07:16 AM
ENGINE 58's Avatar
ENGINE 58
checkercoop , i had a good source tell me just that. i was thinking of the springs on my stock suspension and he told me my stock would be out in no time. so i will wait for bc coils.
Old May 15, 2008 | 07:35 AM
checkercoop
Yeah its really unfortunate I'm going to end up having to live with that gap
Old May 15, 2008 | 02:46 PM
dajiggalo's Avatar
dajiggalo
The lower the drop, the faster the stock shocks will wear out. The rest of the suspension should be OK.
Old Jun 9, 2008 | 09:03 PM
MakoBimmer's Avatar
MakoBimmer
Just how fast does the suspension wear out??? We talking after 4 or 5 years or sooner?
Old Jun 9, 2008 | 09:18 PM
Oxybluecoop's Avatar
Oxybluecoop
I ran mine on Eibach springs for 30k before coilovers with lousy @ss roads and many "oh *****" potholes but they aren't blown.If you want a lower profile go for the springs.
Old Jun 9, 2008 | 10:33 PM
minihune's Avatar
minihune
Using lowering springs you put more stress on the stock shocks.
Probably they will last about 12,000-20,000 miles depending on how you drive, loads your carry, and your driving style.
I had H-sport springs and stock shocks and after about one year and 10,000 miles with just me in the car my shocks were definitely not as good as when new. Ride quality got very harsh enough that no one wanted to ride with me on the street.
Old Jun 10, 2008 | 03:52 AM
dwebber18's Avatar
dwebber18
I just dropped my R56 with H&R springs and I couldnt be happier. The stance is perfect, it handles great and the ride is pretty good, but will get better when I get rid of the runflats. I also did a sway bar so that helps some too. Check out the pics in my sig line to see the MINI after the springs
Old Jun 16, 2008 | 06:57 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy)
dw....did you happen to measure before/after, and did you have to do anything else?
Car looks good. I've got an AB inbound. Can't wait, and want to drop it too, but looking for progressives with about a 1" drop and don't want bone-jarring issues either.
Before & After closeups would be sweet if you have 'em.
Old Jun 19, 2008 | 09:47 AM
miniwilly's Avatar
miniwilly
Which springs?
I have a new Cooper S which I want to lower about 1.25" without increasing ride stiffness. Do any of these springs do that?
Old Jun 19, 2008 | 09:59 AM
dwebber18's Avatar
dwebber18
Take a look at the pictures in my signature line. My MINI is dropped with H&R springs, so if you like that look you can go that route. I think however the only way to not stiffen the ride is to go with coilovers which are ridiculously expensive. WIth the springs I have the ride is a little stiffer but that will be fixed when I get rid of the runflats, so take the whole system into account. Springs/coilover, shocks, sway bar, strut brace, and tires. Granted you can piece it together. I did springs and sway bar, and will do the tires when I need them but am debating on the strut brace cause they are so freakin expensive. And if you want to go for springs I got mine off tirerack.com for $199
Old Jun 19, 2008 | 12:12 PM
miniwilly's Avatar
miniwilly
I thought coil overs might be the answer if the right spring rate was available. I'm not that concerned about cost if I can get the right result. Does anyone have info on spring rates or inherit problems from the currently available coil overs?
