R56 SF bay area only: OBD-II scanner?
Old Apr 28, 2008 | 09:44 AM
poolemac's Avatar
poolemac
Sorry to use the general R56 forum but the NorCal forum is pretty dead.
I need a recommendation for somebody or someplace with an OBD-II scanner tool for the R56. My normal shop is BR Racing in Los Gatos but their tool doesn't seem to want to sync up with my car. Can anyone recommend a shop in the south bay / peninsula area to have some codes cleared? (besides the dealer? )
thank you!
Old Apr 28, 2008 | 10:05 AM
Robin Casady's Avatar
Robin Casady
Some auto supply stores provide that service. I've seen signs for it in several around Monterey. Or get yourself a ScanGaugeII. You can read error codes and clear them. It also provides you with four simultaneous gauge readouts while you drive. You choose from a variety available in the OBC. I usually use it for coolant temp, boost (MAP), mpg, and mph. It will also give you intake temp, ignition delay, rpm, voltage, and other readouts.
Another nice feature is the automatic daily trip meter. It measures max rpm, average speed, average mpg, etc. Resets when the car is off for 8-10 hrs. You can read the current data, or yesterday's data.
Old Apr 28, 2008 | 10:18 AM
MINIAC's Avatar
MINIAC
Try A&E Performance in Campbell at (408) 866-0606.
Old Apr 28, 2008 | 10:59 AM
steaming79's Avatar
steaming79
amazon
Old Apr 28, 2008 | 11:11 AM
COR BLMY's Avatar
COR BLMY
all AUTOZONES "loan" tools including OBD scanners.
You will need to buy it / pay full price.
Read list and clear your code right in the parking lot and return the reader.
A reader is a great tool to own but I have donr this while on a trip and forgot my reader
Old Apr 28, 2008 | 02:02 PM
poolemac's Avatar
poolemac
tried the AZ tool and it's not reading any codes. Guess It's not going to solve the issue I'm having (driver's side door thinks it's open when it's not). Would a tool specific to MINI be able to clear something like this?
Old Apr 28, 2008 | 03:21 PM
Robin Casady
Sounds like you need to go see MINI of Mountain View.
Old Apr 28, 2008 | 05:40 PM
COR BLMY's Avatar
COR BLMY
I think your door open issue is part of a different 'BUS"
Mini may be able to read deeper through the OBD ...
It's dealer time
Old Apr 28, 2008 | 10:24 PM
poolemac's Avatar
poolemac
thanks guys, that's the plan for Wednesday. Hoping I don't get reamed by the dealer....
Old Apr 28, 2008 | 11:42 PM
Robin Casady
Unless this error was caused by some mods you were doing, it should be covered by warranty. You can't have gone past the warranty period yet?
Old Apr 30, 2008 | 08:40 AM
poolemac's Avatar
poolemac
yup
the first thing you said I ran speaker wire into the door. Doing so required unplugging the wiring harness and feeding wires through the tube that connects the door to the car. $150 so far for diag fee... Awaiting more rapeage...
Old May 2, 2008 | 10:10 PM
poolemac's Avatar
poolemac
$950 later...
DevilMeTaz
R60/R61 Stock Problems/Issues
Oct 2, 2015 06:44 AM
RocketUSA
Sep 15, 2015 07:45 AM
Moya45
Sep 11, 2015 02:21 PM
Puggles
Sep 11, 2015 11:53 AM
