R50/53 Top speed Info/Limiter questions...
Old Apr 26, 2008 | 12:33 AM
silversmoke06's Avatar
silversmoke06
Hey guys silversmoke posting another random late night i wonder what.... question
Tonights trivia is, Anyone know what a Bone stock R53 was good for on the limiter was? Did the Jcw make a diffrence?
Whats the car really capible of Delimited. and will it take a whole lot of power to do it.
Dose the Two diffrent gear sets (02-04) Vs. (05-06) Make a diffrence in top speed? or were they geared in the lower half to improve off the line jump?
Im just bored and curious.
Honestly not thinking about trying this... too freaken scary for me. At the track i may though. I don't want to hit some sort of limiter and don't want to be supprised.
Im only at 205 for power though. I want jan's head pretty bad....
beside the point.
Whats everyone think?
Old Apr 26, 2008 | 12:48 AM
barroomhero07's Avatar
barroomhero07
I have a totally stock 03 R53 and it won't do any faster than around 135 but i don't think that is because of a limiter, but rather from aerodynamics (or lack thereof).
Old Apr 26, 2008 | 12:56 AM
silversmoke06
around or exactly?
Old Apr 26, 2008 | 09:45 AM
barroomhero07
can't remember for sure, but in either case i still think it was aerodynamics. i've driven other cars to their limit and the throttle cuts out momentarily and then resumes. The MINI just went there and just couldn't go any faster.
Old Apr 26, 2008 | 09:54 AM
Motor On's Avatar
Motor On
beside the point.
02-04= 136 JCW 142
05-06= 134 JCW 142
It is electronically limited on all, you can actually get go faster in 5th, because the computer doesn't know to reduce the airflow to maintain the limited speed.
Old Apr 26, 2008 | 10:32 AM
silversmoke06
So what could the car do if it had the power to wind out 6th?
Horde i love that programing hole, its pretty funny.
Old Apr 26, 2008 | 10:46 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Jan should take a MINI with all his stuff out to the salt flats.
Old Apr 26, 2008 | 10:59 AM
cucho's Avatar
cucho
145 MPH...it got to 130 fairly quick but after that it took a while to get to the 145 and that was it. I had the pedal to the metal.
Old Apr 26, 2008 | 11:08 AM
silversmoke06
Well i was trying to figure out if it took a buttload of power to do it or your regular 240 horse car could do it.
and if so what is it for laughs. i suppose i could always sit down a do the math...
I just dont want to.
i got a 5 On my Ap calc and was told i never have to do math again.
so i dont wanna
Old Apr 26, 2008 | 03:19 PM
silversmoke06
bump
Old Apr 26, 2008 | 03:28 PM
AKIndiMini's Avatar
AKIndiMini
Maybe one of the lucky ones in Germany can pipe in and tell us if US-spec cars have a speed limiter, and if the gearing change makes any difference at the top end. If anything, I'd guess that the newer ones just get up to top speed faster, and that top speed on our cars is limited by aerodynamics as opposed to hitting redline in 6th gear...
I am a bit curious myself, seems the 05-06 MCS revs just a tad bit higher at highway cruisin' speeds. Not enough (I would think) to make any real difference on top speed. I could be wrong though!
Old Apr 26, 2008 | 03:40 PM
silversmoke06
well supposing you had the power to push sixth all the way out.
and i think that say 200 rpm would make a big diffrence at all out rev
Old Apr 27, 2008 | 06:06 AM
DaveTinNY's Avatar
DaveTinNY
I was maxed out at 133mph on Gran Turismo 5 Prologue in the '06 MCS on the Daytona track. Pedal to the metal. :-) Fun!
Old Apr 27, 2008 | 06:22 AM
Dr Obnxs's Avatar
Dr Obnxs
Now...
so i dont wanna
that's just lazy. This isn't even calculus! It's just red-line, drive ratio and tire diameter. Get off you assss and do the math!
Matt
ps, for extra credit you can make a curve of power going into the wind as a fucntion of speed. It's not hard, and you'll learn something too!
Geeze... kids these days....
Old May 2, 2008 | 12:20 AM
silversmoke06
anyone who wants to sent me the final drive is welcome to ill do the math.
im curious now.
i found out my big block vette is suppose to run only 143.8
but that dosent explain why its seen 162 a couple of times.
could i have the wrong ratio i think so.
Old May 3, 2008 | 05:40 AM
Ric in Richmond's Avatar
Ric in Richmond
Wonderful little program called GEARCALC on the net. Put in all your info and it spits out top speed in gears.
Depending on torque curves you may or may not be able to pull that 6th gear so the lower final drive may be faster!!
http://www.omnilith.net/gearcalc/
Old May 3, 2008 | 05:54 AM
cmt52663's Avatar
cmt52663
in a vacuum, the JCW will pull 165 mph in top gear at 6,850 rpm
the cF on our little bricks is .39
the cF on a halfway slippery car is .29
would anyone care to calculate the hp required to overcome air resistance and actually reach that theoretical limit?
since i'm too lazy, i referred to http://www.mayfco.com/dragcoef.htm
looks like about 375 hp would get 'er done...
Old May 3, 2008 | 08:20 AM
cartar452's Avatar
cartar452
ask Tuls...this is a pic from his car...i think it has like 400whp??
Old May 3, 2008 | 08:24 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
At least the passenger took that picture.
MiteyF
Aug 26, 2015 05:07 PM
3MCS1DJ
Aug 23, 2015 02:08 PM
xpunisherx
Aug 10, 2015 10:50 PM
