Navigation & Audio speaker question
Old Apr 25, 2008 | 04:54 AM
yellowbritishrocket's Avatar
yellowbritishrocket
speaker question
im looking to upgrade my speakers and i have a few questions:
i dont want to upgrade to something i have to cut my door panels to fit...looking for oem size set up that goes into existing spots
plus tweeters that will install with as minimal of a headache as possible
looking to replace front and rear speakers oh and i dont have the H/K set up
Old Apr 25, 2008 | 05:20 AM
PGT's Avatar
PGT
I put MB Quart Premium 6.5" seperates in. The tweeter snapped into the OEM location....secured by a little hot melt to be sure. The woofers fit with a 3/4" MDF trim ring, cut to match the OEM speaker outside diameter. I suspect most quality midbasses would be the same.
Old Apr 25, 2008 | 05:55 AM
pimpedout97x's Avatar
pimpedout97x
x2.
most any 6.5" mid will fit in the stock location, you just need to make 3/4" (i had some that needed 1", so i used 2 1/2" pieces of MDF)
anyways, the mids will probably be the hardest part for you, just becuase you have to make the rings. 1" tweets should fit in the stock pods with minimal work, hell you can even get them to stay with little zipties
Old Apr 25, 2008 | 07:03 AM
yellowbritishrocket
if i can stay with the 5 1/4 size that would be good...im not looking to cut and trim and modify things to to get an extra inch or so in speaker size....if i have to ill make small modifications but im not looking for any outward signs that the speakers have been modified
Old Apr 25, 2008 | 07:12 AM
PGT's Avatar
PGT
if I remember right, you need to do rings for a 5.25. The OEM speaker has a spacer molded in. Very few thin mount speakers out there and you leave a lot of performance on the table with them.
Old Apr 25, 2008 | 07:55 AM
yellowbritishrocket
well if i can keep it looking stock then ill be good
Old Apr 25, 2008 | 08:20 AM
PGT's Avatar
PGT
mine looks stock....no visual hint of anything different.
donniedarko
Oct 21, 2015 01:15 PM
rob76turbo
Sep 15, 2015 10:11 AM
Filmy
Sep 7, 2015 08:27 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
jesterofatlas
Sep 4, 2015 11:23 PM
