Suspension I need help with tire sizes!!!
Old Apr 22, 2008 | 03:19 PM
grillhands's Avatar
grillhands
Can a 225/50/16 fit on our car without rubbing? I have a 205/50/16 on right now and i was wondering if anyone has this setup.
Old Apr 22, 2008 | 03:32 PM
glnr13's Avatar
glnr13
what size wheel? what's the offset? are you lowered?
Old Apr 22, 2008 | 03:53 PM
grillhands's Avatar
grillhands
the car is lowered on tein springs with, i believe, 1.5 all the way around. It's a 16 inch sport max wheel and i'm not sure of the offset. I think i need to do more research. Redskunk if you see this can you please chim in
Old Apr 22, 2008 | 04:00 PM
bahawton's Avatar
bahawton
They're on my car...
JCW suspension with modified rear spring perches for an additional .75" loweing & 16x7 with 42mm offset.
No rubbing on front.
Removed a little material on the rear bumber at the wheel well to stop rubbing at full compression.
Lots of traction!!!
Old Apr 22, 2008 | 04:05 PM
RedSkunk's Avatar
RedSkunk
16x7 with a +38 offset I believe (But check that, it'll say on the inside somewhere).
225/50 would be tall. I had a noise in the rear when the 205/50s were new, that I think were the tires rubbing on the outer plastic arch. The noise disappeared within a few hundred miles.
215/45 would probably fit, might rub same place in the rear. Tire would probably wear out their happy place on the arch lip. I think the big prob would be the arches, since the offset is wide.
Old Apr 22, 2008 | 04:07 PM
glnr13's Avatar
glnr13
you should be ok if the specs are as bahawtons
i personally run a lower sidewall... 225/40/16 on bilstein coilovers all the way down. no rubbing even at the autox. but like i said, my sidewall is 12.5mm shorter than what you plan to run so my account is different
and keep in mind that 225/50/16 is going to be 2.5% slower on the speedomoter. your circumference is going to 1.9" larger than the stock 205/45/17 MINI tire
Old Apr 22, 2008 | 04:24 PM
grillhands's Avatar
grillhands
Thanks guys for your help.
Old Apr 22, 2008 | 05:02 PM
PGT's Avatar
PGT
ibMinihunecopiesandpastesfromtirerack.com
Old Apr 22, 2008 | 05:34 PM
bahawton's Avatar
bahawton
My tires aren't 1.9" taller than stock- They're only 0.4" taller & that's only a 0.2" radius increase. The minimal diameter increase doesn't seem to slow me down because the new tire & wheel package is 60 lbs lighter that stock ; )
Old Apr 22, 2008 | 05:52 PM
glnr13's Avatar
glnr13
LOL
my bad, i meant circumference.
and you're actually .6" taller than the stock wheel/tire combo that i received on my vehicle. i understand it's different from the 16" combo but i opted for the 17"s
but you're right it's only .2"
Old Apr 22, 2008 | 06:19 PM
bahawton's Avatar
bahawton
I keep trying to cut & paste the spec boxes from Tire Rack for my tires & the OE Goodyears but all it does it post @!$%%$% hypertext!?!
Long story short is this...
Section Width: 8.1" stock & 9.1" with my tires.
Overal Diameter: 24.3" stock & 24.7" with my tires.
Revs Per Mile: 858 stock & 827 with my tires.
Tire size calculators are only good for approximations since evey brand tire varies in size. I chose the Conti's for a number of reasons, but one of the main reasons is they're shorter than most other 225s.
Old Apr 22, 2008 | 06:21 PM
PGT's Avatar
PGT
:fail:
Old Apr 22, 2008 | 06:23 PM
Calaway16's Avatar
Calaway16
real interesting bahawton.
Old Apr 22, 2008 | 06:28 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
My opinion
205/45/16
215/45/16
225/40/16 <-might rub a little. Depends on ride height and camber.
If you wanna run 225's but are worried about rubbing...just lower the aspect ration a little bit.
Old Apr 22, 2008 | 06:29 PM
bahawton's Avatar
bahawton
I don’t understand your comments PGT & Calaway16?
Am I missing something?
PGT's Avatar
PGT
215/50/16:
Old Apr 22, 2008 | 06:30 PM
Rally@StanceDesign
^^^ lol, well played
PGT's Avatar
PGT
[FONT=Times New Roman][SIZE=3]I don’t understand your comments PGT & Calaway16?[/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3] [/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3]Am I missing something?[/SIZE][/FONT]
nicely played good sir!!
Rally@StanceDesign
well played
nicely played
Creepy....
Old Apr 22, 2008 | 06:32 PM
bahawton's Avatar
bahawton
I corrected the hypertext problem a couple posts ago- Maybe you need to hit the refresh button your browser?
Old Apr 22, 2008 | 08:23 PM
glnr13's Avatar
glnr13
lol too funny
Old Apr 23, 2008 | 03:49 AM
Calaway16's Avatar
Calaway16
When I read it it was all hypertext. Sorry Now it makes sense
Old Apr 24, 2008 | 03:37 PM
bahawton's Avatar
bahawton
Cool!
I was starting to think my computer had a virus
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
Waszak
Oct 21, 2017 05:55 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
