Navigation & Audio Dynamat: need advice on rear seat removal
Old Apr 22, 2008 | 11:00 AM
Dehn356's Avatar
Dehn356
I'm getting ready to install dynamat in the rear of my 2007 MCS coupe.
Does anyone have any advice on removing the rear seat, etc. to get to the floor.
Thank you in advance.
Frank Dehn
Old Apr 22, 2008 | 11:17 AM
TWON's Avatar
TWON
Just grab and pull!
There are two clips in the front, one on each corner, after that, pull the front of the seat all the way up and there is one more spot that it is connected. There is a little bar in the middle of the back that you will have to get loose by manipulating the seat a bit. While pulling the front up, try to push the back down and free it from its little bracket (this one do NOT just pop off). Good luck!
Old Apr 22, 2008 | 11:26 AM
TWON's Avatar
TWON
Oh, this is the 2nd gen. section... that was for the first gen, I never took the seats out of my R56 so not sure if is the same?
Old Apr 22, 2008 | 02:06 PM
poolemac's Avatar
poolemac
http://coopermods.com/archives/4
Old Apr 22, 2008 | 07:06 PM
Dehn356's Avatar
Dehn356
poolemac: these instructions are outstanding. Thank you very much.
Old Apr 22, 2008 | 08:30 PM
Minidrivr's Avatar
Minidrivr
Robin's thread about his rear seat delete and cabinet may interest you also.
https://www.northamericanmotoring.co...d.php?t=117453
Old Apr 23, 2008 | 03:00 PM
GregW's Avatar
GregW
I have lots of pics for removing the seats here:
http://www.miniacal.com/remove_rear_seats/
Old Apr 23, 2008 | 03:11 PM
Dehn356's Avatar
Dehn356
GregW: Thank you very much. This is going to be a big help and time saver. I appreciate it.
Old Apr 23, 2008 | 04:15 PM
k6rtm's Avatar
k6rtm
I'm contemplating dynamat as well, in stages. The problem areas I see:
(1) inside of doors (major PITA) and front passenger area
(2) inside of the top (no sunroof, have to remove headliner, PITA)
(3) rear area, rear seats
How would you place these in priority order as far as reducing noise?
Cheers--
Old Apr 23, 2008 | 05:30 PM
rwk317's Avatar
rwk317
Many thanks!
kazyn
Oct 25, 2019 02:34 PM
mishanja
Jun 22, 2016 09:59 AM
Mini'mon
Aug 26, 2015 01:02 PM
mini4thewini
Aug 19, 2015 05:18 PM
