Drivetrain Not Starting
Old Apr 20, 2008 | 01:13 PM
1nf3rn0's Avatar
1nf3rn0
Not Starting
Well, i took the MINI for a spin today, but when I was done with lunch I went to start the car and *click*. Thats all I got out of it. I checked my ground strap, got a jump, checked the battery voltage (which was at 12.5, so the battery is fine). I was finaly able to get it going with a push start, but the car still wont start on its own. I think the starters cooked, which is reparable. Any other ideas what might be wrong with it?
Old Apr 20, 2008 | 05:05 PM
UKSUV's Avatar
UKSUV
One of your cables might be bad... Hmm..sounds like a starter tho. But I dont have the qualifications to diagnose problems on 200HP Mini's....only 115...
Old Apr 20, 2008 | 05:08 PM
checkmate2006's Avatar
checkmate2006
Yeah what the hamster powered cooper guy said and check the positive terminal under the bonnet it may have come loose and so make sure all your terminals are clean of any corrosion. I had that same problem a long time ago.
Old Apr 20, 2008 | 05:11 PM
Dr Obnxs's Avatar
Dr Obnxs
Here you go...
Won't start and click, try a jump.
If jump works, it's the battery, if the jump doesn't but a push does, then it's the starter, the ignition switch, or a connection (check the high current path from the bat to the starter).
That's about it.
Matt
Old Apr 20, 2008 | 05:16 PM
1nf3rn0's Avatar
1nf3rn0
ya, jump didn't work. I've dismissed the battery from volt testing. Ignition off, I'm at 12.5v. With ignition on, i get 12.1v and with the key to the start position, 11.5v. I'm thinking I will just let the dealership take care of it. I just dont have time to replace a starter myself....
That's about it.
Matt
Old Apr 20, 2008 | 05:46 PM
lhoboy's Avatar
lhoboy
BAD BATTERY.
An unloaded battery should read 13.2 volts and not drop below 12-12.5 when cranking. You don't have enough juice to kick in the starter solenoid. When trying to jump, leave the cables hooked up for a couple of minutes before trying to crank.
Old Apr 20, 2008 | 05:53 PM
1nf3rn0's Avatar
1nf3rn0
I had them hooked up for 10 minutes... If it was the battery and a cell was bad, it would be reading far below that level.
Originally Posted by lhoboy
BAD BATTERY.
Old Apr 20, 2008 | 07:34 PM
herbie hind's Avatar
herbie hind
agreed. 12.5 should be fine but could still be bad amp wise . mine read good but wasn't . take it to a sears or the like and they can test it .
Old Apr 20, 2008 | 07:49 PM
1nf3rn0's Avatar
1nf3rn0
Ya, when I have time I'm gona run it down to Murrays. If thats not the problem, its getting flatbedded to the dealer...
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
LordOfTheFlies
Oct 19, 2015 05:02 PM
Steffen.Johnson
Aug 23, 2015 08:30 PM
