R50/53 Budget aero look
Old Apr 19, 2008 | 06:53 AM
mattco's Avatar
mattco
Budget aero look
I love the aero look but not the price.Got these parts over the counter at Keeler Motors in Lathem NY. So far the voting is split, my wife liked the old look better until the parts were on the car. The upper grill was direct bolt on but the bottom grills tabs did not fit the original slots so mods had to be done. Lost the S on the back of the car a while back due to a towel drying accident but the kids called it the superman car so this was fitting.
Matt
Attached Thumbnails Budget aero look-mini-2-.jpg   Budget aero look-p1010001-2-.jpg   Budget aero look-p1010004-2-.jpg
Old Apr 19, 2008 | 11:26 AM
Jenn B's Avatar
Jenn B
Yep, I had this on my 04 way back in the day. There is a good write up on here somewhere about how to trim the bottom part to fit.
Love the look. Makes the car more aggressive without spending an arm and a leg.
Old Apr 19, 2008 | 11:32 AM
Boxcars's Avatar
Boxcars
hiya mattco
love the areo grill look, how hard was the bottom one to make fit?
boxcars
Old Apr 19, 2008 | 12:33 PM
mattco's Avatar
mattco
The piece on the bumper covers tabs are in the wrong place to fit the original slots. I had to mark for the new grill and cut identical slots. I drilled holes in the ends of the new holes and cut out the middle waste. The grill snapped right in with a little persausion. Whole job took about 31/2 hours including removing bumper cover and reassembly.
Matt
Old Apr 19, 2008 | 12:44 PM
Boxcars's Avatar
Boxcars
matt
thanks for the info, will be doing it soon.
Old Apr 20, 2008 | 06:43 PM
UnderTheBonnet's Avatar
UnderTheBonnet
Looks good dude. I'll be doing mine this week. What's the trick to removing the bolts on the upper stock grille. They seem to want to just keep spinning. I'm thinking I need to hold something in place while turning the bolt but I'm not sure what. With all the plastic stuff, I don't want to break anything.
I think I'm making this more difficult than it should be.
Old Apr 20, 2008 | 06:53 PM
mattco's Avatar
mattco
Those nuts are a real pita. That part is stronger than it looks. Push out from the back while using a 1/4" socket drive to loosen the nuts.
Matt
Old Apr 20, 2008 | 06:55 PM
UnderTheBonnet
Thanks for the tip!
Old Apr 20, 2008 | 08:26 PM
uRabbit's Avatar
uRabbit
Looks like the bottom grille is sticking out a bit on the left side (right side, if sitting in car).
Old Apr 21, 2008 | 07:17 AM
mattco's Avatar
mattco
The whole grill does stick out more than the original but is actually even on both sides. the shadow makes it look different.
Matt
Old Apr 21, 2008 | 07:20 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
You can cure that with a little trimming or dremel work
Old Apr 21, 2008 | 12:31 PM
uRabbit's Avatar
uRabbit
Yep. It can sit flush. That's why it's taking me a while to get the bottom one on.
gar56
Nov 15, 2016 06:41 AM
TISGOD
Nov 13, 2015 04:12 PM
danielmini
Oct 20, 2015 02:09 PM
Fourflys
43
Oct 20, 2015 09:42 AM
BMC_Kid
Sep 27, 2015 04:31 PM
