Brake pads-less dusting desired...
Old Apr 19, 2008 | 01:32 AM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
Currently have OEM pads/rotors with 20K miles on 'em.
I absolutely HATE the brake dust and I just had a set of R84s powdercoated white (BEAUTIFUL IMHO)...I want to change to pads with less dusting.
Recommendations?
I do have a brand-new set of Mintex Reds on hand...
Thanks!
Erika
Old Apr 19, 2008 | 01:34 AM
Marwan's Avatar
Marwan
Check your PM
Old Apr 19, 2008 | 04:01 AM
AutoXCooper.com's Avatar
AutoXCooper.com
Bobcats at AXC by Carbotech. Lower dust better stopping power. http://www.autoxcooper.com/ctbrakes.html
Old Apr 19, 2008 | 05:16 AM
BlimeyCabrio's Avatar
BlimeyCabrio
I've been running Hawk ceramics with OEM rotors for the last 25K miles. VERY low dust that is very easy to clean. But wish they had a bit more bite. I'm about to install Ate rotors and Carbotech Bobcats...
Old Apr 19, 2008 | 06:01 AM
Marwan's Avatar
Marwan
+1 for Carbo Tech...
Old Apr 19, 2008 | 06:34 AM
Bahamabart's Avatar
Bahamabart
Recommendations?
Thanks!
Erika
Most of the ceramics produce less dust - PBR, hawk, ect....
Old Apr 20, 2008 | 04:00 PM
wellzy's Avatar
wellzy
carbotech is the only way to go made in US and no dust. 1521 (bobcat) has almost no dust and they will not cut your rotors like the hawk will
Old Apr 21, 2008 | 04:41 AM
SNEEEZY - Erika
Rattle Can Queen!!!
Hmmm...ceramics seem to be what everyone is suggesting...will I need to upgrade my 21K+ OEM rotors?
Thanks!
Erika
Old Apr 21, 2008 | 07:22 AM
Bahamabart's Avatar
Bahamabart
Thanks!
Erika
Condition of your current rotors is a seperate issue - if they are good, then no replacement if not then replace. If they need replacing, use the board like you are now. There are some good aftermarkets at a good price.
If you decide to look at ceramics - get prices for the PBR/Axxis ceramics. I know people running them and are very happy w/ the little dust they produce and the bite they give. Some feel they bite better than the hawk ceramics
Peter carries the PBR ceramics (minspeed.net)
Old Apr 21, 2008 | 07:27 AM
Marwan's Avatar
Marwan
As per many recommendations. You should machine or turn your rotors when you put new pads. This is to get the best performance and pad life.
Old Apr 21, 2008 | 06:06 PM
wellzy's Avatar
wellzy
with that many miles you will need to get them turned regardless of what pads you use inless you use oem again. my wife has them on her r50 today a washed it, the rims i hosed then toweled dry. the towel came up almost clean. it was that easy
Old Apr 21, 2008 | 08:47 PM
wrxmini's Avatar
wrxmini
absolutely,when you turn your rotors you have clean slate,so when you bed them you are trying to deposit pad material on to the new rotor face,thats what makes them perform at their best
BernieCoop
Sep 10, 2021 03:15 AM
Sep 10, 2015 10:52 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
squawSkiBum
Sep 2, 2015 09:56 PM
