Suspension Just installed cf strut bar
Hey I just intalled a carbon fiber strut bar i purchased from a fellow Namer. I had a feeling the ecu cover wouldnt fit but i was hoping by some grace it would fit
. So i installed it and i was able to squeez it in. So i took it out for a spin...it felt nice..popped the hood looked for anything wrong looked fine. Closed hood and the right side doesnt fit fully
. So im planning on going out later tonight and taking off the ecu cover and shaving it down a bit. Im guessing the ecu doesnt like heat so ill do my best to leave as much plastic on there as possible. Anything else i should look out for?
no haha i closed the bonnet and didnt really look at it. so i took it out for a spin and looked at it again and i then saw that the bonnet locks but the right side stays up. I can still fit a finger under the right side to get the bonnet lock but it wont open cause its latched
exactly will be shaving the ecu cover, just wondering if theres anything to watch out for
Moss sells a low profile ECU cover if your experiment doesn't work so well. Here is a link
http://www.mossmini.com/Shop/ViewPro...eIndexID=59562
If the ECU cover fit under the bar then IT"S NOT THE PROBLEM.
The hood liner is hitting the bar. Try the old soak and slam. Get a spray bottle and soak the area of mat that hits the bar. Once it is saturated slam the hood shut a couple time. You may need to repeat this a couple times but it does work.
If you still have the problem then try trimming the liner.
My $.o2
LB
My $.o2
LB
Yea you guys are right i shaved the ecu and even part of my air box, the hood closes a bit more but i will try the spray bottle method and will shave some of the hood if that does not work, thanks for the suggestions
pics when im not feeling lazy
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
