How to repair side skirt damage?
Old Apr 9, 2008 | 03:15 PM
succubus's Avatar
succubus
Sorry for the repost, I posted this in the first gen mini int/ext mod section but then thought it would get more attention here. So here is the link to the other thread:
https://www.northamericanmotoring.co...d.php?t=135668
The summary of it is that I need some advice on how to repair this:
Old Apr 9, 2008 | 03:32 PM
TReed's Avatar
TReed
Man, at first I thought someone was posting a picture of my car, I have very similar damage to my driver's side skirt. :(
I am planning on replacing the whole thing because I did not know if it could be repaired.
Old Apr 9, 2008 | 04:20 PM
succubus's Avatar
succubus
I'm confident that with the right set of materials, tools, time, and determination, that I can repair this myself and get it fairly close to hidden.
What I'm thinking is that I'll remove the entire skirt, clean it up really nice, and epoxy it together as clean as possible. Then, I will use some CR touch-up paint in an airbrush or something to make the lines dissapear.
If anyone has any better ideas, advice from experience, let me know.
Treed, have you received a quote on the cost of replacing the entire piece?
Old Apr 9, 2008 | 05:35 PM
Minidrivr's Avatar
Minidrivr
Google plastic repair. Comes up with lots of stuff. I have seen kits for motorcycle fairings that worked very well.
Old Apr 10, 2008 | 04:51 AM
condor27596's Avatar
condor27596
A lot of people on my CRX site use a plastic welder
from harbor frieght (fenders, doors, bumpers, etc are plastic
and prone to cracks).
You have to figure out what type of plastic it is too.
I'm not sure if harbor frieght has the complete selection of
welding rods. I've seen kits on ebay where there are a variety
of rods, or rods and the welder.
You need compressed air source to run the thing.
Once you weld it back, you fill in a little with bondo, sand
and paint.
Although you might be able to get away with some type of glue
applied with a toothpick to the crack, and touch up paint.
NOTE: you weld this thing from the backside, not the front.
Very good results have been obtained doing the above.
The epoxy method has not worked well (not saying it wont in
your case) for me. I ended up just buying new fenders.
Old Apr 10, 2008 | 05:21 AM
D3m0N's Avatar
D3m0N
if I remember right the replacement side skirt is $75 plus shippiing then paint so like $200 complete or so. I dont know if your going to be able to repair hidden but just throwing the number out there as an FYI.
Please lets see pictures when complete!!
Old Apr 10, 2008 | 05:50 AM
condor27596
If you are on the ultra budget
you could try:
1. take the thing off,
2. use masking tape, the blue kind works best
and tape it from the front side making sure to
cover the cracks well.
3. from the backside, take #80 sandpaper and
really rough it up, then clean with a strong
solvent like xylene (be very careful to not get this
on the paint part). Then take one of those fiberglass
repair kits (available at car parts store) and fiberglass
the whole back side. You'll want to use the whole kit.
Making it like 1/4 inch deep, with the fiberglass mesh too.
All the way to the rear and maybe 6-8 inches toward the front.
NOTE: Do not put too much on at one time it will get too hot
and melt the plastic.
When it is completely dry take off the tape and
you can use a razor blade to scratch off the little
fiberglass line bump where the crack was.
I have had decent success this way (still ended up replacing
the part when I painted again).
You really have to use overkill on body panels. They undergo
a lot of stress, and, not much glue/epoxy/whatever sticks to them
well at all.
But after thinking about it if you are looking for a $20 fix, that
is your best bet.
Old Apr 10, 2008 | 01:10 PM
succubus's Avatar
succubus
I'm not on the "ultra" budget, just don't want to spend $800 to repair something that shouldn't have ever happened... :(
Anyway, I took the skirt off and discovered it is PUR GF 20 (whatever that means). The PUR part is PolyUrethaneResin. I am trying to get my hands on one of these as we speak:
http://www.urethanesupply.com/5600ht.php
They are actually ~$150 + shipping and would be handy to have around. The set comes with PUR welding rod, so that should do it. I'll keep you all posted.
Old Apr 10, 2008 | 02:33 PM
TReed's Avatar
TReed
I was told the painted piece from Minspeed is $350.
Old Apr 11, 2008 | 04:23 AM
condor27596
I book marked that thing. Thanks for finding it.
Old Apr 11, 2008 | 02:56 PM
succubus's Avatar
succubus
Read this thread I started here:
http://www.eng-tips.com/viewthread.cfm?qid=214279
Will be interesting to see if this PUR is thermoplastic or thermoset. I hope I don't get attacked by cyanide gas!!!
Old Apr 11, 2008 | 03:07 PM
succubus's Avatar
succubus
Thanks for the tip on Minspeed. I spoke with Pete, very nice guy. He's gotta get me an actual number tomorrow, but his unpainted part price was very reasonable. I may not need that plastic welder after all for this job, though I am stoked I'll have it anyway for stuff :D (I'm gonna attempt the repair regardless)
Old Apr 11, 2008 | 05:45 PM
TReed's Avatar
TReed
I was going to say if you want my damaged piece to practice on and work with I'd sell it to you pretty cheap
Mine is just cracked in a couple of places, it didn't break all the way off.
Old Apr 12, 2008 | 02:03 PM
succubus's Avatar
succubus
Yeah? How much? I wonder what it would cost to ship to LV? Probably not enough to make it worth the effort...
Old Apr 14, 2008 | 07:32 PM
succubus's Avatar
succubus
Well, I got the plastic welder today. Very cool. I found out that PUR used in automotive is generally thermoset, which cannot be welded with heat. However, I followed the instructions for the thermoset by cutting a v-groove in the back with a Dremel, and "glueing" the parts together using urethane "rod." I'll tell you what, it works.
Unfortunately, I didn't have an extra set of hands so the pieces aren't mated up properly. The cracks are more visible than I'd like, so I'm going to wait till my wife gets home from her work trip in a few days and tear it apart. I'll have her hold it together for me while I do the "welding."
It seems quite sturdy, and because the "glue" is actualy polyurethane, the joints are flexible and sturdy. This may work out afterall.
Hey Treed, do you have a picture of your damaged panel?
Old Apr 14, 2008 | 07:49 PM
TReed's Avatar
TReed
Here's a crappy cell phone pic. There's a piece of black gorilla glue tape on the crack. Once the crack gets to the bottom, it goes along the black/red 'seam' for a few more inches. :(
I should hopefully have my new piece tomorrow. *fingers crossed *
Old Apr 15, 2008 | 05:34 PM
succubus's Avatar
succubus
Hmm, does't look too bad, much less to repair than mine. Ship it to me!
So hey! My wife and I worked together (she was the jig lol) to weld these pieces back together. I think we did a fantastic job. I only welded the backside, as opposed to both sides as the instructions said, but I want to preserve the paint and I think it'll be good enough. We shall see.
I'm going to have to get some new clips for attachment, and some touch-up in CR to cover the cracks. I'll post a pic when its done.
woodstudio
Mar 15, 2020 08:28 AM
Philipangoo
Sep 16, 2015 11:54 AM
Accessory Products
Aug 25, 2015 10:03 AM
cm.d
Aug 19, 2015 08:51 AM
Minibeagle
Aug 13, 2015 10:00 AM
