R50/53 noise from front end
Old Apr 7, 2008 | 01:11 PM
freeskier's Avatar
freeskier
today on the way home from school, when i lifted off of the gas and let the car roll, there was a terrile clunking/popping noise from under the front end. any ideas? the sound is also more sever when the car is in neutral.
Old Apr 7, 2008 | 01:45 PM
Ancient Mariner's Avatar
Ancient Mariner
check your motor mounts.
Old Apr 7, 2008 | 02:19 PM
freeskier's Avatar
freeskier
when i check them, what exacly am i looking for?
Old Apr 7, 2008 | 03:35 PM
freeskier's Avatar
freeskier
no one else has had this problem?
Old Apr 7, 2008 | 04:09 PM
rhawth99's Avatar
rhawth99
The passenger side motor mount on the '05 and '06 MCS is notorious for leaking - you'll see a gummy black spot under the mount if it is leaking. You may even have a bonus black spot on your garage floor.
Old Apr 7, 2008 | 04:12 PM
bahawton's Avatar
bahawton
The driver's side axle was just replaced on my car after only 8.9K miles!
It was making similar noises, plus clicking while turning...
Old Apr 7, 2008 | 05:27 PM
freeskier's Avatar
freeskier
just checked around undwer the hood. the passanger side mount that the motor sits on top of looks damaged. i would like to swap thatas well as the bushings in the mount under the motor. the noise pretty much only happens when coasting down a hill, looks like the motor is contacting the frame up front. outmotoring sells a powerflex motor mount bushiung kit, which mounts will this kit replace and whichones will be left alone?
boostedhaze
Jan 2, 2018 07:26 PM
silence2-38554
Nov 12, 2015 09:39 AM
gmonde
Sep 8, 2015 06:37 AM
damncajun
Aug 17, 2015 08:25 PM
FatherG
11
Aug 7, 2015 07:49 PM
