The right tool for the job...
Old Apr 7, 2008 | 11:31 AM
91Eunos's Avatar
91Eunos
The official BMW pulley puller showed up from CMS today, along w/the crank thread protector (and the new intake btw!) and all I can say is wow! Not only did the shipment arrive in record time (as usual), the tools are absolutely perfect.
I removed the crank pulley to clean off the assembly lube w/absolutely no effort whatsoever. The tools weren't cheap but absolutely worth every penny! Even at twice the price...
Ironically, the local BMW dealership also called today, seems they ordered the exact same tools for me when I asked if they were available last week...so now I have 2!
Henry, you have a package heading your way for your patience and understanding... Did your new tensioner bar show up from CMS yet?
Old Apr 7, 2008 | 11:53 AM
WP4LDU's Avatar
WP4LDU
Hi 91eunos,
I just got back from my weekend trip. I will check the mail tomorrow. Henry
Old Apr 7, 2008 | 12:24 PM
91Eunos's Avatar
91Eunos
the pkg from CMS should be there if their shipping speed to me is an indicator...You'll have another one from me coming in a day or so (however long it takes it to get there MPS from Ramstein).
Old Apr 7, 2008 | 12:27 PM
WP4LDU's Avatar
WP4LDU
Thank you!
I will let you know as soon I get it. Henry
Old Apr 8, 2008 | 10:00 AM
WP4LDU's Avatar
WP4LDU
HI 91eunos!!
I got the tool from Custom Mini today. Thank you
Henry
Old Apr 9, 2008 | 02:09 AM
91Eunos's Avatar
91Eunos
Great! It's the new design w/the shorter pins (shouldn't bend)...
The pkg I sent to you has 2 tools in it; one is pretty small (thread protector--looks like a bolt) and wrapped in bubble wrap so don't throw it away by accident!
Old Apr 9, 2008 | 03:37 AM
Poppa Bear's Avatar
Poppa Bear
OK, fellas, long story short: about a month back I asked the dealership for an estimate for a tensioner tool and they told be €50! Wow, great price!! They said it would take about a week, ten days and would call once it arrived. I called them yesterday and they told me that the quote was wrong; it would be €120 to order. I knew it was too good to be true. So, where do ya'll recommend that I get this tool? I'm not looking for cheap, Harbor Freight tools but I'm not real keen to pay €120 for an occasional, once a year tool either. Thanks!
Cheers!!
Old Apr 9, 2008 | 09:43 AM
abuzavi's Avatar
abuzavi
91, the question we're all dying to hear answered --
Did they send you another shirt?
BURN IT!
Old Apr 10, 2008 | 09:50 AM
WP4LDU's Avatar
WP4LDU
Hi 91Eunos!!
I got the second box today. I'm impressed... Thank you for the Crank pulley tool.
You are the MAN.
Old Apr 10, 2008 | 10:43 AM
Poppa Bear's Avatar
Poppa Bear
Anybody?
Cheers!!
Old Apr 10, 2008 | 12:01 PM
WP4LDU's Avatar
WP4LDU
Hi Poppa Bear!!
Yes, 120 euros it is expensive. You can get it from same place 91Eunos got his CustomMinishop.com or outmotoring.com for about $65.00.
Cooper S Belt Tensioner Tool
$64.95
Old Apr 10, 2008 | 12:30 PM
91Eunos's Avatar
91Eunos
What Henry said... Or come down to my house and we'll do it here w/Henry's old bar that's now welded back together Frankenstien style! Lord knows I have plenty of experience running the belt now...and my 9-year-old son is the master of holding the tension bar whilst I route the belt over the pulleys!
BTW Henry, do you want the old one back? I owe you big time... I'm glad you like the pulley puller...that thing is a piece of art to me. I can't believe how easy it was to pull the pulley w/that thing. I really like the dished end of the thread protector--machined to take the tip of the puller bolt w/the pressed in self-centering bearing. Noice.
Also did you notice that the puller bolt has a very fine thread pitch to spread the load over more surface area? Nice touch.
The plate w/the holes for the retaining bolts looks like nice quality tool steel too... I'm very impressed w/the overall quality of the tool set; especially for the price.
Old Apr 10, 2008 | 02:09 PM
WP4LDU's Avatar
WP4LDU
Hey thank you again!!
I don't need the old one back. So what do you use to press the crank pulley back in place? Henry
Old Apr 12, 2008 | 12:32 PM
91Eunos's Avatar
91Eunos
I used some 12mm threaded rod w/a couple of washers and a nut until I could get the pulley on far enough to use the (old) crank bolt. Once I had it tight and confirmed it was aligned w/the other pulleys I took that bolt out, cleaned the threads in the crank nose one last time and then put the new bolt in w/a lot of Locktite Red.
The other tool I got from BMW that bolts to the pulley to use like a wrench made it really easy to torque the crank bolt to 85 ft-lbs.
Old Apr 12, 2008 | 01:12 PM
WP4LDU's Avatar
WP4LDU
Great!
Thank you again for the tools. Henry
Old Apr 13, 2008 | 10:25 PM
Poppa Bear's Avatar
Poppa Bear
Henry! Please don't forget to send the specs so I can make my very own Patented, Official Henry Tensioning Tool!!
Cheers!!
Old Apr 14, 2008 | 07:02 AM
WP4LDU's Avatar
WP4LDU
Poppa Bear,
I will try to explain:
(2) M-6mm x16mm bolts
For the tool, get the big metal door Hinge from Hornback or Baumark. Drill two 6 mm holes starting with a 5mm bit work your way up until the bolt fit tight on the metal hinge. On the piece of metal from top to bottom measure 6mm and drill a hole. For the second hole from top to bottom 13mm and drill a 6mm hole and for the diagonal distance in between, they are 34mm apart. Let me know
Henry
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
OutMotoring
Mar 3, 2017 06:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
aldito2
Sep 30, 2015 10:44 AM
tcjake
Sep 30, 2015 08:14 AM
