MSW Type 11 - 17's...what size tire?
Old Apr 3, 2008 | 06:20 AM
tarsky68's Avatar
tarsky68
You guys that are running MSW Type 11's...
what size tire are you running? 205/45/17?
Thanks in advance for your help!
Old Apr 3, 2008 | 10:07 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
It's 17x7" +37mm offset
Assuming stock suspension then-
205/45-17
or
215/45-17
If you lower your MINI then-
205/45-17
205/40-17
or
215/40-17
+37mm offset makes the wheel stick out from the wheel wells so the tire must not be taller than stock tire diameter or you risk rubbing with any lowered MINI.
Kimolaoha
Dec 5, 2020 09:32 PM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
