R52 Garage Remote: Where?
Old Mar 23, 2008 | 07:42 AM
jrlpking's Avatar
jrlpking
My '08 MCSC does not have the built-in garage door opener.
I don't like the idea of having the regular remote clipped to my visor when I want to walk away from the car with the top down for a couple of minutes to go into a store.
How do others handle this? Do you have the remote hidden somewhere, take a chance on the visor route, or lock it away in the glove when not in use?
Old Mar 23, 2008 | 07:59 AM
MiniDaMoocher's Avatar
MiniDaMoocher
I asked this question a few months ago and ended up taking the advice of others and velcro'd it under the toggle switches. It's hidden out of the way, fully reachable, and functions only a fraction worse than on the visor.
Old Mar 23, 2008 | 08:02 AM
bad venge's Avatar
bad venge
I opened my remote , soldered wires to the switch , ran them out of the case and installed a switch in the unused center switch of the toggle panel, you can also install the switch under the dash
Old Mar 23, 2008 | 08:13 AM
quikmni's Avatar
quikmni
I have mine connected to one of Ian's Auto-Up circuit boards so that it is controled by a toggle switch installed in one of the previously unused switch panel positions. I have the remote stashed inside the lower dash panel. Works fine but does limit the range. Makes for a very clean installation.
Old Mar 23, 2008 | 09:37 AM
chpsk8's Avatar
chpsk8
I took this garage door opener and velcro'd it to the inside of the drivers door pocket.
http://www.amazon.com/Liftmaster-key.../dp/B00023RR10
I can reach in the pocket and hit the button and the opener remains invisible to the public. Best of all it took less than a minute to apply velcro and install.
Old Mar 23, 2008 | 03:03 PM
jrlpking's Avatar
jrlpking
Thanks!
Thanks everyone for the ideas. Sorry I didn't check the archives first. I will next time....
Jeff
Old Mar 23, 2008 | 04:32 PM
eager2own's Avatar
eager2own
+1 to ALL of the above -- except I actually get better range now!
Neither Ian or I could figure that one out -- but I ain't complaining.
Old Mar 23, 2008 | 04:41 PM
irieman's Avatar
irieman
I didn't even velcro mine- I use the visor clip to hang it on the piece of plastic just under the toggle switches (where a lot of people put the AUX input jack). On the '06s there's a "trap door" like piece of plastic, complete with clips that let you open it up (If I hadn't broken my camera, pics would be right here: _______________ )
Hope that helps!
Old Mar 24, 2008 | 05:51 PM
rnbradford's Avatar
rnbradford
Clipped to the plastic surround just under the steering column. Can't be seen from outside the car and easily reachable.
Richard
Old Mar 24, 2008 | 07:56 PM
iamhollyb's Avatar
iamhollyb
I just put mine inside the armrest - it fits great and it's not committed to the car, since I still have my Mom-mobile (Odyssey) that I have to use with the kidlets, and need the opener clicker for those times.
-Holly
Old Mar 24, 2008 | 08:23 PM
mini4rb's Avatar
mini4rb
I installed a unit from F2P Technologies http://www.f2ptechnologies.com . You connect it to your high beams and replace your garage door opener pad in your garage or add it as a second button somewhere in the garage. Flashing your high beam activates a transmitter that sends a signal to the new button pad.
Old Mar 24, 2008 | 10:40 PM
brownflyer's Avatar
brownflyer
jrlpking,
You can upgrade your rear view mirror to one that has the transmitter built in. I think they can be had for around $300 from the dealership. All the wiring should already be in place so it's an easy plug and play.
OR, you can do what I did...
Old Mar 27, 2008 | 04:00 PM
bradclark's Avatar
bradclark
Brilliant idea! I installed mine tonight!
Thanks!
Old Mar 27, 2008 | 04:40 PM
AeroJammin's Avatar
AeroJammin
I believe that newministuff has a relay that can connect a door opener to the unused buttons on the MFSW. If you aren't afraid of the splicing it could be a good option.
Old Mar 28, 2008 | 03:31 AM
MY4thMINI's Avatar
MY4thMINI
wow
and to think for the past 2 years i just clipped my remote to the visor....
i guess i was going for a retro look
Old Mar 28, 2008 | 03:41 AM
dickdavid's Avatar
dickdavid
I don't have a convertible, but I didn't want mine to show. Here was my solution. The wiring idea was borrowed from somebody else, and I've heard of better solutions. However, this works.
Old Mar 28, 2008 | 04:46 AM
PuppetMaster2u's Avatar
PuppetMaster2u
+1 for velcro-ing it under the switch panel. I like your solution too dickdavid
Old Mar 28, 2008 | 04:52 AM
PGT's Avatar
PGT
Originally Posted by brownflyer
jrlpking,
actually, MINI jacked up the MSRP to $499. Glad we got our cabrio with it from the factory....$200 if I remember right.
The option and one I used for my Wrangler....a keyfob. It depends on what brand opener you have, but I had this one for Chamberlain:
Old Mar 28, 2008 | 06:35 AM
MiniDaMoocher
jrlpking,
Awesome mods guys. I bought one of Ian's latest Auto Up Circuits about a month ago and did a similar wiring from my GD opener to his circuit which uses the door unlock toggle to trigger the opener. If it wasn't for Ian, I never would have even imagined that I could solder a bypass switch into my opener. It came out really clean, and uses the same location for the opener as I had previously. Now if someone came up with a way to use the extra buttons on the steering wheel.....that would be even better
Old Mar 28, 2008 | 03:46 PM
AeroJammin's Avatar
AeroJammin
Here is the link to what you'll need to hookup the opener to the MFSW buttons
Old May 2, 2008 | 01:28 PM
MC 33-EJB's Avatar
MC 33-EJB
I just cliped mine to the plastic surround on the lower portion of the drivers seat. done deal.
Old May 2, 2008 | 02:58 PM
iamhollyb's Avatar
iamhollyb
That's what I did - I bought a small one that is made for a keychain (and even came with Velcro) and stuck it under the toggles. Out of the way and mostly not noticeable.
-Holly
Old May 3, 2008 | 09:10 PM
Ryan909's Avatar
Ryan909
I have mine on my key ring. I once had a garage door opener in the car. It was broken into and for some reason they did not open the garage but it got me to thinking what if?
Doc Pain
Mar 10, 2021 04:50 AM
minimofo
Dec 26, 2015 12:03 PM
vulkandino
Oct 31, 2015 08:29 PM
chowpott
Oct 19, 2015 08:37 AM
navybsn
Oct 4, 2015 03:27 PM
