R50/53 how to get motor mount failed oil off??
Old Mar 21, 2008 | 10:43 AM
hexproject's Avatar
hexproject
hi, i am sure some of you got motor mounts failure and have to tried to get the oil off the frame.
any liquid thats will do the job fairly well to get motor mount failed oil off??
Old Mar 21, 2008 | 10:59 AM
MariettaMini's Avatar
MariettaMini
Mine didn't sit on the frame too long, but some dawn and water in a spray bottle helped...it's worth a shot
Old Mar 21, 2008 | 11:17 AM
hardtail15's Avatar
hardtail15
get some engine degreaser spray at will
Old Mar 21, 2008 | 12:55 PM
Mr. Frodo's Avatar
Mr. Frodo
Simple Green.
Old Mar 21, 2008 | 12:59 PM
ScottRiqui's Avatar
ScottRiqui
Soap and water should be fine, as well as Simple Green, but test any engine degreasers or harsh cleaners on an inconspicuous spot first.
The body-coloured paint under the hood isn't clearcoated (or, at least not with the same quality clear that's used on the exterior panels), and it's not the toughest stuff. Things like brake cleaner, carb cleaner, and even 3M Adhesive Remover will lift the paint, especially if you do any rubbing will trying to get the oil stains out.
Old Mar 21, 2008 | 02:18 PM
hegira's Avatar
hegira
Like Scottriqui mentioned (not in so many words), the paint used under the hood sucks eggs.
I would try Simple Green, or WD-40, which is great stuff for gently cleaning any petroleum-distilate-based stains.
And it's gentle on your hands! You're soaking in it! (Sorry. 1960's flash-back)
Old Mar 21, 2008 | 02:37 PM
Capt_bj's Avatar
Capt_bj
Ditto
Yep
under the hood doesn't get clear...just color. And color w/out clear is not durable.
WD-40 is what I'd use or
Spray with POR-15's marine clean then hit it with my steam cleaner....but you probably don't have those
so.....
this is a case where a trip to one of those coin operated power washer places might be a good idea....just becareful where you point the
spray head
Old Mar 22, 2008 | 03:10 AM
umberto's Avatar
umberto
how did you know your motor mount failed?
Old Mar 22, 2008 | 05:32 AM
Gil-galad's Avatar
Gil-galad
Take a look at the pics in this thread:
https://www.northamericanmotoring.co...d.php?t=116181
You might also hear a new rattle, something akin to a golf ball rolling around in your glovebox, but the fluid mess in the engine compartment is a dead giveaway.
Old Mar 22, 2008 | 07:01 AM
MariettaMini
I parked on a slight incline and noticed the hydraulic fluid on the ground
Old Mar 22, 2008 | 04:36 PM
SkinnerG's Avatar
SkinnerG
Hi All,
This is my first post as I just recently purchased a 06 MCSa PW and have been reading through the forum learning as much as I can about it.
After reading this thread I realized the oil residue on the body around and under the motor mount was probably due to a failed motor mount. Since this was there when I got the Mini and is not freshly wet how can I tell if the mount was replaced? Is there a test I can do or does the replacement mount look different?
Have really enjoyed reading this forum and hope in time I will also be able to contribute as well.
DixonL2
Apr 13, 2021 08:05 AM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
PelicanParts.com
Aug 14, 2015 11:07 AM
minipopkart
Aug 13, 2015 05:22 AM
