R50/53 Power Steering Pump Fan Operation
OK,....I've searched thru lots of threads,..cant find exactly what I'm looking for. I'm not having any problems, but I would like to know the operation conditions needed for the P/S cooling fan to operate...does it run all the time?..[havent looked to see if it does]..is it temperature controlled/thermoswitches?/relay/timers?....just was curious to know, so I know what to watch for....
thanks,
Steve
thanks,
Steve
thanks,
Steve
thanks,
Steve
Cheers,
Charlie
Power Steering fan ~ Is it supposed to run all the time ?
RE: MINI 2003 - R53 Power Steering fan proper operation. Is not running when car on.
I checked all previous threads on issues with regards to MINI's Power Steering fans, mine is down to the wire on a 90 day warrany from non Mini dealer - and she is going in on Tue for unrelated matter;
Do they operate off a thermostat switch and only come on as needed ?
or
Do they come on with ignition start up, to run 24/7 ?
Thanks for the help.
or
In regardst to this thread, What does the A/C have to do with the Power Steering pump exactly... why would turning on the A/C make the power steering pump fan initiate ?
That is what the thread states. Maybe this is why the pumps are failing, they should be rigged up to run all the time ?
In my day I have heard/seen some dumb **** manufacturer's designs before but this one take the cake !
The PS fan comes on when the low speed function of the cooling fan comes on. This is determined by engine temperature. The AC increases the engine temperature, thus causing the fan to engage. When the temperature decreases the fan disengages.
What's the easiest way to get the low speed cooling fan to engage to test to see if the power steering fan spins?
Thanks.
Thanks.
Fan SUks
Drove the car up on Rhino Ramps and removed the fan's housing bolts with a SAE 1/2 socket ( YUP ~ SAE 1/2" Fits tighter on any 13 mm nut on MINI's) I cleaned it up with some WD40 and a rag, replaced and it, started up the car and it didn't come on. I was not sure if the fan's bearings heated up and cooked the elect motor, or if the PS fan was thermostatically controlled.
So I entered a post here and got no immed response.
So I checked the 5 A fuse behind the panel next to drivers side left foot well. Found a blown fuse, and the spare 5 A was gone too.
So it must have blown before.....
Fired up the car, turned on the A/C which automatically turns on the High speed Engine Cooling fan, and about 30 seconds later........I thought my girlfriends cat got caught up in the serpentine belt
The PS Fan was making the most terrible racket one could only imagine. Must be bad bearing(s) for the fan I guess.
Was this fan an afterthought or something ? Or, purely the end result of German barley and hopps intoxification
Either way, not much thought went into its design, placement or inherint climatic hazzards. One of my 7 yr old twins could have done a better job with an eraser board and markers
You can just start the car and let it warm up. You can see and hear the low speed cooling fan come on. The PS fan should come on at the same time. It will go off as soon as the cooling fan stops. Turning on the AC speeds up the process.
Jag owner
Cheers, Pass the Beer Nuts !
Etrain
16
Aug 5, 2024 04:37 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
