R50/53 My run flat & DSC light went on for a couple minutes...
Old Jul 28, 2003 | 11:34 AM
jivanivan's Avatar
jivanivan
It was weird. Yesterday, I was driving around and I make a u-turn and suddenly my flat tire light lit up. I stopped at the gas station and everything looks fine. I drive away with it on and then 30 seconds later, my DSC goes on. I was very worried and then they both just turned off. Anyone ever have this? Is this normal?
Also, how many clicks does it take to turn on/off the DSC? Mine take about 2 or more to get it lit up and turned off. Is that right?
Old Jul 28, 2003 | 11:36 AM
hafid's Avatar
hafid
Happened to me. It's a problem that is fixed via a diode recall. I had it done. Take it to your dealership.
DSC is affected by only one click of the switch for me, but I think you have to hold it down for a sec. Try that instead.
haf :smile:
Old Jul 28, 2003 | 11:48 AM
jivanivan's Avatar
jivanivan
Thanks Hafid, I'll tryi that. BTW SUPER COOL PICS in your sig there. Hows did you take that angle? ANd did you buy a new shift boot?? I'm trying to get my interior to red. ANy info would help.
-Ivan
Old Jul 28, 2003 | 11:58 AM
MGCMAN's Avatar
MGCMAN
Ivan,
You stated that you performed a U-turn immediately prior to your light coming on.
Welcome friend to "that's the way its supposed to work", a show where we explain those everyday phenomena that just seem to happen. Sorry. Your system is designed to detect changes in rotational speed between the different wheels. By performing the u turn you merely activated the advisory warning. Nothing to do but reset it. Get our your manual, move the ignition switch into the number 2 position and press that little flat tire button under the hand brake. Nuthin' to it. No need to freak this is normal. Happens to folks all the time.
Old Jul 28, 2003 | 12:04 PM
hafid's Avatar
hafid
MGCMAN - thanks for that info. I've made several U turns since and I don't get this issue any more. I made some really fast ones too since I was in a hurry. Anyway, perhaps that recall fixed that issue?
Ivan - thanks for the comments on the sig. A slight angle to my stance was all that was need to get that shot. I have the blue shift book and if you look reeeeeeeal close the ebrake is also lapis blue. Those were incl. with the car. I have not seena red leather one.
Minicoop78 painted some of his trim red. You should PM him for pix. His car is seriously powerful.
haf :smile:
Alkaidovich
Jan 30, 2021 01:35 AM
sabjcw
Aug 14, 2015 07:40 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
jrezzo
Aug 9, 2015 10:32 PM
