5-speed getrag oil change??
I've changed the oil in a few transmissions. Makes a bigger difference in some more than others, regardless of mileage... makes me think driving style is a big factor... for the older Midlands, it seems to make a BIG difference in shifting smoothness. We've been using Redline MTL.
You probably won't get a straight answer from BMW/MINI regarding this as according to them all of their transmission come with a "lifetime" fluid... ..but they fed us the same line of b.s. 5 years ago when I changed the fluid in our M3.
Changing the fluid is pretty easy. With the engine reasonably warm, undo the fill plug then the drain plug. I use a funnel with an extension hose from the top side of the engine fished down into the fill hole. Much easier/faster than any of the consumer-pump set-ups I've tried. Will take a little less than 2 quarts. IIRC, the Getrag uses a hex-wrench (10mm?) on the plugs.
It seems to really depend... I haven't had to change the fluid in a MC Getrag yet, but there have been varying degrees in improvement to the 6spds and 5 spd Midlands. The Midlands with a bit under 50K on it made quite a bit of difference... and there was also a a lot of mettalic debris attached to the magnetic drain plug.
How can I determine what type of transmission I have?
I have an 05 Mini (R50) with 75k miles on it and afte reading the posts I think I need to change it. Does Redline MTC wotk for either type of trannie?
Found the Answer
I have a 04 Mini R50, but I don't know if it is a Getrag or Midland. Can you tell from the VIN or do you need to call the dealer? I realized they changed from the Midline to the Getrag in 2004; therefore, the change only applies to the 2005 on models. My bad...
Anyone change the fluid on the Getrag 5 speed? The sticker on the transmission is a blue sticker and says LT-3?
According to Redline, that oil closely matched their D6 ATF, which is a pretty light oil. Anyone have any experience using this in their transmission?
Anyone try Redline MTL in the 5 speed Getrag? This oil is thicker, which seems like it would be better if you drive your car hard?
Kimolaoha
Jul 5, 2023 01:04 PM
