R50/53 03 MCS clutch pedal adjustable?
Old Mar 12, 2008 | 01:38 AM
JT-KGY's Avatar
JT-KGY
I searched and didn't find anything on this forum...
Is the clutch engage point adjustable for the 03 Mini S?
Right now the cluch will engage (or disengage) almost right above the floor...
Is that normal? Is where the clutch engage adjustable?
Thanks,
Old Mar 12, 2008 | 04:59 AM
k_h_d's Avatar
k_h_d
that is where my clutch engages.
Old Mar 12, 2008 | 06:48 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
The clutch system is hydraulic and non-adjustable.
What you are noticing may be (not is) one of the signs of a failing slave cylinder. Depending on the mileage of you car you may want to have that checked out.
Old Mar 12, 2008 | 07:30 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
That is a good place to have your clutch engage for performance driving.
Old Mar 12, 2008 | 10:31 AM
JT-KGY's Avatar
JT-KGY
So your clutch engages at the same spot (pretty much right above the
floor)?...
Old Mar 12, 2008 | 10:32 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
From the people I talk to they usually want the engagement point as high as possible. The reason being is the less throw of the pedal, the quicker they can change gears.
When I had a Spec 3+ put in my car the throw changed from about 1/2 the throw to about 1/4 the throw. Worked rather well this past weekend at the track.
Old Mar 12, 2008 | 03:02 PM
JT-KGY's Avatar
JT-KGY
So... no adjustments?
Old Mar 12, 2008 | 05:34 PM
Jhud's Avatar
Jhud
Old Mar 13, 2008 | 09:22 AM
KevM's Avatar
KevM
Nope
Look at post 3 again
Zettinger
Aug 25, 2015 04:04 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
Powershift
Aug 16, 2015 05:14 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
